E3 spark plugs
E3 spark plugs
Post by chevellelaguna on Sat May 03, 2014 10:27 pm
Anyone running those E3 spark plugs?  Basically have three prongs over the electrode .....supposed to be a better burn hotter spark. I'm a loooong way from thoughts of spark plugs...but, when my ride was together it ate spark plugs and spit them out. Literally melting the electrodes. 12.5:1 compression and iron heads and 46 degrees of timing kills my AC Delco plugs. Regular driving on the street required less timing and low revs, not "lead footn' it " at EVERY stoplight. Just thought of maybe changing to these E3 down the road.
Street Cred : 16
Re: E3 spark plugs
Post by dynchel on Sun May 04, 2014 7:49 am
I had thought about those last plug change, but ended up using regular ac delco's instead ( they are a bit expensive). I have a Msd 6a2 box, with a accell hei super coil & Taylor wires.
Re: E3 spark plugs
Post by 77mali on Sun May 04, 2014 9:16 am
I ran E-3's in my Jeep once. Shortly after install I started getting a load of misfire codes. I've only gone with the factory original recommended plugs since then on any of my cars. They might be OK for a big combustion chamber but in my case, they ran way too hot.
Re: E3 spark plugs
Post by pila on Sun May 04, 2014 12:43 pm
All those extra ground electrodes on a spark plug don't do all that much. In fact, plugs stay cleaner with one electrode. The latest & greatest aircraft plugs have only one ground electrode, instead of the 2, 3, or 4 that were used for 60+ years, and the latest and best are iridium, and ONLY about 65 bucks each ! Very Happy
Re: E3 spark plugs
Post by Dinomyte on Sun May 04, 2014 10:53 pm
pila wrote:All those extra ground electrodes on a spark plug don't do all that much. In fact, plugs stay cleaner with one electrode.  The latest & greatest aircraft plugs have only one ground electrode, instead of the 2, 3, or 4 that were used for 60+ years, and the latest and best are iridium, and ONLY about 65 bucks each ! Very Happy
Well sign me up for 8!  We'll do that instead of a mortgage payment this month  affraid
Aside from the shock, my understanding is that it's not the number of electrodes, it's how "Good and clean" your spark is, and that's all about how clean is your plug to begin with.
Re: E3 spark plugs
Post by bracketchev1221 on Mon May 05, 2014 8:25 am
What gas are you running at that compression? I have had no problems running the NGK V power plugs in my chevelle. That is almost 14:1 compression on race gas.
Re: E3 spark plugs
Post by chevellelaguna on Mon May 05, 2014 8:32 am
When I run race fuel there's no issue, happens when I run anything less like Sunoco 94 have to set the timing back
Street Cred : 16
Re: E3 spark plugs
Post by bracketchev1221 on Mon May 05, 2014 9:46 am
That is just wicked detonation on pump gas. I don't think any plug is going to withstand that. What camshaft, heads and piston are in it?
Re: E3 spark plugs
Post by chevellelaguna on Mon May 05, 2014 12:29 pm
It's a zero decked 355 small block with 12.5:1 TRW forged 3/8" domed pistons, 74 cc iron heads 882 castings (I took out a coffee can of material, porting them) the cam isn't crazy it's a Crane hydraulic with .580 lift int/exh. The cranking compression is around 260psi. (The pistons were spec'd at 12.5:1 with 76 cc heads) luckily with 94 octane and the timing set at 39 degrees it detonates at high RPMs but doesn't rattle or ping.
Street Cred : 16
Re: E3 spark plugs
Post by bracketchev1221 on Mon May 05, 2014 1:15 pm
I am going to say the cam @.050" duration is too small for that much compression and the timing is too high. You should never have to go past 40 degrees total timing. With 12.5-1 compression and a steel head, I would be at a minimum of 260 degrees duration @.050".
Re: E3 spark plugs
Post by chevellelaguna on Mon May 05, 2014 3:14 pm
I'll dig out the cam card, I forget what the duration is. I'm sure you're right though. I know the iron heads aren't the best but, aluminum ones were out of the realm of being affordable in the 90's. Planning on aluminum heads and a larger cam in the future. One thing at a time for now.
Street Cred : 16
Re: E3 spark plugs
Post by pila on Mon May 05, 2014 9:54 pm
With that high a ratio, maybe more duration in cam design would close the intake valve a bit later, reducing compression a bit...
Re: E3 spark plugs
