steering shaft
+4
8 posters
steering shaft
Does anyone know what this bushing is called and where i might be able to get one? it seens only the cotter pin is holding it in.
Re: steering shaft
Yes that is just held in by the cotter pin. I would start looking for shifter bushing kits. Is this car automatic or a stick, and column or console? That ear was usually the column release for the key when the car was put into park or with a stick, sometimes reverse.
Re: steering shaft
It is a automatic with a hurst dual gate on the floor (although it was originally a column shift) Thanks for the response, now if only i don't get the deer in the headlights look from the parts store guys.
Last edited by dynchel on Tue Mar 18, 2014 11:23 am; edited 1 time in total (Reason for editing : added details)
Re: steering shaft
Try the HELP stuff first. If not, just hit a TRUE hardware store. Not like home depot. A store that has drawers of bolts, nuts, all that stuff.
Re: steering shaft
Measure the opening, and try McMaster-Carr if you can't find one anywhere local.
74Malibu383- Donating Member
Re: steering shaft
That connection is supposed to have a rubber grommet in the arm, with the little plastic bushing inside of the grommet. I believe I bought those from OPGI, or maybe one of the other suppliers, like Dixie Monte Carlo, or....?
You need just the grommet, according to that picture. A thin washer next to the cotter pin is a good idea too...
Bill
Bill
Re: steering shaft
Thanks for the responses, it has needed this for a while & I will definitely put a washer behind it. I just had no idea what it was called (ie what to ask for)
Re: steering shaft
http://www.ebay.com/itm/NOS-65-87-Chevy-Pick-up-C-10-GMC-All-GM-CARS-Shifter-Linkage-Column-Bushing-/221386592281?pt=Vintage_Car_Truck_Parts_Accessories&hash=item338bab5019&vxp=mtr
http://www.ebay.com/itm/NOS-AUTO-TRANS-COLUMN-GEAR-SHIFT-LEVER-BUSHING-S10-S15-BLAZER-JIMMY-CUTLASS-/181348289339?pt=Motors_Car_Truck_Parts_Accessories&hash=item2a39334b3b&vxp=mtr
1973montec- Donating Member
Re: steering shaft
Thank you sir, I just bought it.1973montec wrote:http://www.ebay.com/itm/NOS-65-87-Chevy-Pick-up-C-10-GMC-All-GM-CARS-Shifter-Linkage-Column-Bushing-/221386592281?pt=Vintage_Car_Truck_Parts_Accessories&hash=item338bab5019&vxp=mtr
Re: steering shaft
Found these searching for the GM part numbers in the links.
YearOne sells the bushing:
https://www.yearone.com/Product/1967-81-Firebird/9860N
GM Parts sells "sleeve kit" but doesn't say whats all included:
http://www.gmpartsdirect.com/results.cfm
Hawk03- G3GM Enthusiast
Re: steering shaft
Well I bought the eBay post (that 1973 montec posted..thanks again for that) The kit was nice ac delco nos in the original plastic bag (although for thirty dollars I feel a little ripped off) While I had it apart I sandblasted the rod and painted it machinery grey. It definitely looks better (not falling apart anymore)
Re: steering shaft
It looks " professional" which is what most folks like.....
Re: steering shaft
It does. I really need to clean up my engine bay.
Re: steering shaft
I installed my linkage and noticed I was missing the washer/bushing (GM 1377083) that goes on the frame by the spring.
This is the cheapest one I found at $1.18 shipped. I haven't installed it yet but looks like it will fit.
http://www.ebay.com/itm/281283833773?item=281283833773&viewitem=&sspagename=ADME:L:OC:US:3160&vxp=mtr
(Not my linkage just showing location)
Re: steering shaft
I'll have to look closer at mine, I knew I needed the obvious one above, but didn't really look closely at the bottom. For $1.18 I may just replace it for the h3ll of it.
Re: steering shaft
Interesting...I think mine was/is missing. Didn't even realize I needed it. +1 :-)
Re: steering shaft
It's a nylon sort of washer, which is flat on one side, and domed on the side that goes into the bracket on the frame. It should also have a flat washer on the flat side, so the spring doesn't dig into the nylon plastic.
If the linkage gets sloppy, the hole in the nylon washer may be worn oversize. I just replaced one on my partners pickup truck because it was worn oversize. Now he knows what gear he is in !
