accerator cable
accerator cable
Post by Bret Mullikin on Wed May 28, 2014 2:54 pm
I have been talking about this in the intake topic, but I thought I should put it out on its own. Does anyone know where to get, the brand, or the part number of the correct accelerator cable for a 74 Malibu with a 400 and quadrajet? I can't find the info anywhere.
Thanks
Bret Mullikin
Re: accerator cable
Post by Als 73 on Thu May 29, 2014 1:12 am
Have you tried napa they had some when I was looking for one about 5 years ago.
I think I may still have an nos one in my garage ,can check tommorrow. You can send me am PM if you like.
Al
Als 73
Re: accerator cable
Post by pila on Thu May 29, 2014 9:50 pm
If you know how long it needs to be, from the firewall plastic grommet part, to the end on the housing, it may help to find one. I have one, but not sure which carb it's for, like 4bbl or 2 bbl ......
Re: accerator cable
Post by chevellelaguna on Thu May 29, 2014 9:57 pm
I retained one from a 2bbl carb, and just made a lengthened plate that bolted to the slot and then to the linkage on my Holley carb. As long as it's wide open when you floor it, the carb doesn't care which one you use.
Street Cred : 16
Re: accerator cable
Post by Bret Mullikin on Thu May 29, 2014 10:02 pm
Thanks,
Pila. I don't know what length it should be. That's why I'm trying to find the part number for an original. The one I bought might work, but there is a huge loop in it due to excessive length.
Bret Mullikin
Re: accerator cable
Post by 1973 454 MONTE on Mon Jun 02, 2014 5:24 pm
i have these,but dont know what exactly they fit.
come to think of it,i have the top one on my quadrajunk.
Street Cred : 35
Re: accerator cable
Post by pila on Mon Jun 02, 2014 8:19 pm
I bought my '74 Malibu in 1990, and removed the 2bbl for a 4bbl. I had the local dealer check all the Chevy dealers for a 4bbl cable, and the parts guy found one out of state some place. It was the only one in the system at that time, so I guess I got lucky for once.
So, one the cables I have is a 2bbl type... I'll measure them & see if they are different or the same.....
Re: accerator cable
Post by Dinomyte on Tue Jun 03, 2014 12:09 am
I've changed over from a 2bbl to a 4bbl also, and had the same issues.
First thing to know is what bracket(s) do you have?
The 2bbl had one bracket for both the throttle cable and the trans kickdown, was no where near right for the 4bbl. There are 2 different setups for the Qjet (that's what I remember, as I had the wrong one furst time out)
Re: accerator cable
Post by Bret Mullikin on Tue Jun 03, 2014 6:19 am
Thanks everyone. I cut about 3 inches off of the Napa '75 cable and Ace had the exact same cable stops that were put on by the factory. The only difference was that the factory put them on in a much nicer way with its 100 ton press than I did with my wire strippers. I also had to file down the plug that fit in the firewall. Thanks again for everyone's help.
Bret Mullikin
Re: accerator cable
Post by Silentknight85 on Sat Jun 25, 2016 8:58 pm
I found a few accelerator cables tonight that should fit our cars
CB15430V (NOS) or CB15431V (Repro) @ thepartsplace
https://www.summitracing.com/parts/atp-y277
also (search as a 74 malibu): http://www.rockauto.com/en/catalog/chevrolet,1974,malibu,5.7l+350cid+v8,1054482,interior,accelerator+cable,5892
Silentknight85
Street Cred : 4
Re: accerator cable
Post by Mcarlo77 on Sun Jun 26, 2016 8:49 am
I know little about interchangeability of these cables among the various years/motors.  I do have a couple original spares off '75/'76 350 engines (one each from a 2bbl & 4bbl) and they measure just shy of 21" lg.  According to GM, these would be part #1248077.  Seems there may be a difference in some years in the manner in which the cable attaches to the carb and/or attaches to the retaining bracket on the intake.  Here are the GM part numbers:
#336961 ('73 8 cyl)
#1244125 ('74 2BC)
#1244126 ('74 4BC, 350-400)
#1244127 ('74, 454)
#1248077 ('75-'77, 350/400 & '76-'77, 305)
#1248078 ('75, 454)
The Parts Place #CB15430V shows it's GM #1248077. Summit's cable numbers show theirs to be 2-3.5" longer than what I measure on mine.
Street Cred : 58
Re: accerator cable
Post by Silentknight85 on Sun Jun 26, 2016 9:24 am
I discovered that this morning, as well, when I measured my cable. The rockauto/summit cables are too long. My current cable is pretty beat up and the mounting tabs are broken. I'll likely buy the repro cable from TPPI, hoping that it's a repro of #1248077, i.e. the same length.
Silentknight85
Street Cred : 4
Re: accerator cable
Post by Mcarlo77 on Sun Jun 26, 2016 11:14 am
Just make sure of the end that attaches to the carb is the same as yours. I found an old e-Bay listing for pt# 1244126 ('74 4BC, 350-400) and it looked like it had the kind of end that snapped over a ball stud as compared to mine (1248077) that has an eyelet. Not sure if this really matters, but wanted to mention it.
Street Cred : 58
Re: accerator cable
Post by 73ss on Sun Jun 26, 2016 9:14 pm
I ran into the same headache a few years back. It started when I swapped in a overdrive trans. Ended up making my own cable bracket by cutting & welding 2 small block brackets together to fit the big block. None of the aftermarket brackets were  any good. They would flex with full pull on the TV cable. The accelerator cable is a junkyard piece from a mid 80's full size olds, had to trim down some plastic where it goes through the firewall. perfect fit otherwise. Couldn't find a G3 accel cable with a long enough pull to go WOT.
Street Cred : 10
Re: accerator cable
Post by Silentknight85 on Mon Dec 04, 2017 8:17 am
I now have TWO broken accelerator cables. One that came with my car and one that was sourced from a salvage yard. The plastic mounting tabs just don't hold up to age, I guess. So, I'm going to buy a brand new one. As has been mentioned, the cables that are said to fit our cars are are too long (3-4 inches too long). I did find that the 74-85 Camaro cable is around the same length (21.380 in) as our stock accelerator cable.
Short of putting one side-by-side with a G3 A-body cable to compare differences, I currently don't see any reason why a Camaro cable won't work. I'm going to bite the bullet and order one to see if it will work. I'll let you all know what I find.
Silentknight85
Street Cred : 4
Re: accerator cable
Post by Hawk03 on Mon Dec 04, 2017 9:53 am
I used this bracket and cable and they both work great. Its a universal kit so you will need to adjust the cable to make it the correct length.
https://www.amazon.com/Spectre-Performance-24283-Throttle-Bracket/dp/B000BPZ36A
https://www.amazon.com/Spectre-Performance-2431-Braided-Throttle/dp/B0008G5FZ6/ref=pd_sbs_auto_4?ie=UTF8&refRID=0KRCDPCZPXD78MJ3D2EP
Its not OEM but it works.
Street Cred : 12
Re: accerator cable
