73 El Camino
Page 2 of 2 Previous  1, 2
73 El Camino - Page 2 Empty Re: 73 El Camino
Post by dynchel on Tue Aug 05, 2014 4:05 pm
Get the copper easy bend line..you wont regret it. btw the flair nuts should be 3/16ths standard.
Post by Joe73 on Tue Aug 05, 2014 4:18 pm
Question. Are you going to install the line lock before or after the proportioning valve? Before the valve will keep your brake lights on, after the valve and no brake lights.
I see that you have a new prop valve so you wont be doing away with that like some guys do.
Street Cred : 73
Post by LS_Quest on Tue Aug 05, 2014 4:35 pm
Line lock before the factory proportioning valve.
The proportioning valve we're getting is for the rear. A simple one-in one-out valve. We'll tap into the line that runs to the rear somewhere under the driver seat. Since we're upgradeing from factory disc/drum setup to 13" C5 front and Impala rear disc, we'll need to adjust wheel lockup as close to front/rear equalization as possible.
LS_Quest
LS_Quest
Post by LS_Quest on Wed Aug 06, 2014 11:07 am
dynchel wrote:Get the copper easy bend line..you wont regret it.  btw the flair nuts should be 3/16ths standard.
Thank you.
Mental note: Copper... 3/16ths...
LS_Quest
LS_Quest
Post by LS_Quest on Fri Aug 08, 2014 8:54 am
The plan was to start on this thing today, but...  My boss' mother passed away so he is headed to TN this morning.  Needless to say I'll be at work all day and besides, the weather is looking like rain nearly all weekend.  We don't have a garage, so we are at the mercy of Mother Nature.
Starting to sound like a broken record:  Stay tuned...
LS_Quest
LS_Quest
