Stainless brake lines
In case someone is looking for a stainless brake line kit for our cars.
https://www.facebook.com/marketplace/item/3193255114140995/?ref=browse_tab&referral_code=marketplace_general&referral_story_type=general&tracking=%7B%22qid%22%3A%22-2311197903299449773%22%2C%22mf_story_key%22%3A%22395238911477464272%22%2C%22top_level_post_id%22%3A%22395238911477464272%22%2C%22commerce_rank_obj%22%3A%22%7B%5C%22target_id%5C%22%3A395238911477464272%2C%5C%22target_type%5C%22%3A6%2C%5C%22primary_position%5C%22%3A16%2C%5C%22ranking_signature%5C%22%3A2131395599108279505%2C%5C%22commerce_channel%5C%22%3A501%2C%5C%22value%5C%22%3A0.00028160630027032%2C%5C%22upsell_type%5C%22%3A3523%2C%5C%22candidate_retrieval_source_map%5C%22%3A%7B%5C%227153260164711809%5C%22%3A3020%2C%5C%227041455082642914%5C%22%3A3001%7D%2C%5C%22grouping_info%5C%22%3Anull%7D%22%2C%22lightning_feed_qid%22%3A%22-2311201339024922385%22%2C%22lightning_feed_ranking_signature%22%3A%223620441199563652086%22%2C%22ftmd_400706%22%3A%22111112l%22%7D
Here it is on Inline tube so you can check applications.
https://www.inlinetube.com/products/schb7304
Re: Stainless brake lines
this is Just for 1973 -1975 according to the website 76-77 are different at least in part number wise ...... I also know shipping has went up.... but he was saying to me it would $40 or so and I just sent a sway bar thru fed ex and we all know how big them are was only $23 and change for that to go to a Member here
Going to do some Digging as Inline is closed today was just going off parts houses that were open
I NEED THEM SO BAD
I NEED THEM SO BAD
Joe73 likes this post
Edit: Inline tube Ebay store is showing two different Kits 1973 - 1975 then another for 1976-1977
So gonna go with first Observation is that their different applications BUT WHY ??
Got me on that one. Only thing I would think is maybe something with the threads on the proportioning valve. Just like the changeover on the exterior door handle to the shorter length and I believe metric threads on some of them.
1973-1975 have 9" rear drum brakes while 1976-1977 have 11" rear drum brakes - lines will be different on the rear axle with the different size drums.
Iggy- G3GM Member
Iggy wrote:1973-1975 have 9" rear drum brakes while 1976-1977 have 11" rear drum brakes - lines will be different on the rear axle with the different size drums.
Thats very interesting Iggy!! Thanks for posting that.
I have my original 3.42 73 chevelle rear in storage. In the car is a 1977 monte rear (11" drums) which has been built and houses my 4.10 gears. I ordered the 73 chevelle brake line kit and installed it and had no issues with it lining up.
Limey, just food for thought.
I have the backing plates off a 1977 Monte Carlo axle for the 11" drums. I also have a 1975 Olds 442 axle (factory c-clip eliminator) that I will rebuild for my '75 Laguna. When I get the line kit, I will get a 1977 it even though there is no reason the earlier kit should not work - the rear cylinders are less than one inch off and the line should bend to fit that.
Iggy- G3GM Member
