Holley TPS
Holley TPS
Holley makes this cool Throttle Position Sensor for carb'ed engines.
http://holley.com/534-202.asp
"Holley Performance Products is proud to announce the introduction of their Throttle Position Sensor (TPS) kit for Holley Carburetors with electric chokes. This kit makes is possible to run electronic transmissions in a carbureted car.
The kit supplies the needed signal to an electronic transmission such as a 4L60E or 4L80E. They drive directly off the primary throttle shaft for accurate voltage readings and position sensing. They can also be used for data acquisition."
