Control/Trailing bars
I was looking at this set:
http://www.ebay.com/itm/1973-1977-CHEVROLET-A-BODY-ON-CAR-FULLY-ADJUSTABLE-REAR-CONTROL-TRAILING-ARMS-/281206887648?pt=Motors_Car_Truck_Parts_Accessories&hash=item41793c94e0&vxp=mtr
Any opinions? Anything better for the $$? I don't necessarily need the adjustable uppers. My original to the car set are pretty rusty and the bushings are shot and I have a lot of unwanted movement.
I am running the stock sway bar and don't have plans to go with anything different.
SSTOOLMAN- Donating Member
Re: Control/Trailing bars
http://pmtfabrication.com/product/1973-1974-1975-1976-1977-chevelle-regal-le-mans-boxed-rear-control-arms
This is what I have, a little cheaper since the uppers aren't adjustable. They seem well built.
dynchel wrote:http://pmtfabrication.com/product/1973-1974-1975-1976-1977-chevelle-regal-le-mans-boxed-rear-control-arms
Are you happy with them? Did they make a difference in the handling?
I can't honesty say they made a difference because when I replaced the arms I also put in new springs, and added a sway bar (it didn't have one at all). I also have the frame support braces. (More of a good measure addition than a actual upgrade). I have no complaints except that to use a factory sway bar it needs to be spaced down slightly, so that it will clear the rear bushing.
BTW the car handles good. Only real upgrade on the front is I put a larger one inch sway bar with urethane bushings. (To replace the factory 7/8ths bar)
Your welcome, I also have relocation brackets welded in & the bar is mounted to the top of the arms.
Here's what the support bars look like
dynchel wrote:I can't honesty say they made a difference because when I replaced the arms I also put in new springs, and added a sway bar (it didn't have one at all). I also have the frame support braces. (More of a good measure addition than a actual upgrade). I have no complaints except that to use a factory sway bar it needs to be spaced down slightly, so that it will clear the rear bushing.
Funny you say that about spacing the bar down so it doesnt hit the bushings. I was just going through my factory sway bar hardware ( bar has been out of the car since the 80's) and I have 8 washers. Four of them are round in shape and the other four are hex in shape. So I hit the service manual and it states that if you have spacers use them. And I had to or the bar would hit the bushings. But it was a little puzzling to me when I have 8 washers. But it worked out. Some coincidence.
That's interesting that even with all OE pieces it needed "shimmed down"
» 1986 chevelle or malibu lower trailing arms wanted
» NOS ladder bars for G3's
» Never seen these type of traction bars before.
Yesterday at 4:25 pm by 77camino
Tue Mar 26, 2024 1:35 pm by Whisperer
Tue Mar 26, 2024 8:33 am by Finn Monte
Mon Mar 25, 2024 1:37 pm by Joe73
Sun Mar 24, 2024 6:39 pm by g3chevy / Mr Pontiac
Fri Mar 22, 2024 1:21 pm by Joe73
Thu Mar 21, 2024 1:58 pm by Limey SE
Thu Mar 21, 2024 7:23 am by Joe73
Wed Mar 20, 2024 12:33 pm by Limey SE
Wed Mar 20, 2024 8:26 am by Limey SE
