Sealing exhaust manifolds--what should I use?
Post by dhw3971 on Fri Dec 05, 2014 4:27 pm
When re-installing my exhaust manifolds should I use the flat metal gaskets or can I use "gasket in a tube"?  I already have some Permatex Ultra Copper sealant at home and according to Permatex it can be used to make exhaust manifold gaskets.  info link--click here
dhw3971
Re: Sealing exhaust manifolds--what should I use?
Post by Joe73 on Fri Dec 05, 2014 5:12 pm
Id go with metal ones like stock.
Street Cred : 70
Post by dynchel on Fri Dec 05, 2014 7:04 pm
Joe73 wrote:Id go with metal ones like stock.
X2
Post by fishhead on Wed Dec 10, 2014 10:14 pm
I always had good luck with the metal ones.I don't trust rubber goo except for a quick fix on stubborn collector gasket leaks.
fishhead
Post by Dinomyte on Wed Dec 10, 2014 11:00 pm
X2
Me too, and they'll be so much easier to remove if you need to.
Post by pila on Thu Dec 11, 2014 9:53 pm
Originally there were no gaskets used, just metal to metal...still works for me.
Post by dhw3971 on Thu Dec 18, 2014 5:03 pm
I took the collective advice and put metal gaskets on. I used a bit of high-temp sealant just to get them to stick to the cylinder head long enough for me to bolt on the exhaust manifolds..PITA fighting gravity in that location.
dhw3971
Post by fishhead on Fri Dec 19, 2014 3:11 am
Yep,don't want to do that job twice.
fishhead
Post by brownbomber77 on Mon Dec 29, 2014 2:33 am
I like using the copper gasket stuff made by permatex. Comes in a spray can. has always worked with everything I have used it on
brownbomber77
Street Cred : 4
