small pockmark in 400 cylinder wall
Post by fishhead on Tue Dec 09, 2014 9:48 pm
I bought a used sbc 400 oem bare block that was magnafluxed and checked out crack-free (powder residue still in cylinders),but there is a small pockmark in one cylinder wall that I need to have checked before I dump my "selfish Santa" money into the machine shop.Is sonic testing the only way to know how deep that pockmark goes into the cylinder wall surface or is there some way to get a tiny depth gauge on that pockmark?
fishhead
Re: small pockmark in 400 cylinder wall
Post by chevellelaguna on Wed Dec 10, 2014 6:13 am
Is it a standard bore block? Aren't you going to re-bore the cylinders. That'd be the only way to get rid of it, if it was mag'd the crack would show up...if there was one. Tell the shop to pay closer attention to that cylinder. Makes me second guess why the block was for sale in the first place....especially after being mag'd.
Street Cred : 16
Post by 77mali on Wed Dec 10, 2014 6:45 am
A 400 is a "Siamese" bore. The wall in the block between all the cylinders is closer together than say a 305/350 & leaves less room for over-sized bores. If it's small they may be able to flame weld a patch & then just a good honing might fix it. IDK if you can sleeve a 400 but that might be another option.
Post by bracketchev1221 on Wed Dec 10, 2014 7:09 am
Where in the ring travel is it?
Street Cred : 14
Post by fishhead on Wed Dec 10, 2014 2:30 pm
Luckily it's a standard bore block. The bb-sized pockmark is about 1/2" from the bottom of the bore toward the crankshaft side.I eyeballed it closer and it isn't as deep as I thought.I knew when I bought it there was a risk because there is evidence of a possible rod bolt hitting the bottom of the "pockmarked" cylinder but all the damage is in the safe zone at the very bottom on the crank side.If all checks out ok I'll throw some money at it to beef up the bottom end.
fishhead
Post by bracketchev1221 on Wed Dec 10, 2014 3:34 pm
If it didn't show up as cracked, bore it and hone it, and you'll be fine. That will take off the high edge around the pock mark if indeed it did get hit with something.
Street Cred : 14
Post by pila on Wed Dec 10, 2014 9:42 pm
If it's that close to the bottom I wouldn't get excited about it, if it's that small. Mine is bored .040 over, from .030, to get rid of a groove from a broken ring, but I would not want to do .060 over.....core shift etc to think about etc.
Post by fishhead on Wed Dec 10, 2014 10:02 pm
Thanks guys,I tend to get all "Charlie Browns Christmas Tree" over scratch-n-dent car parts.I can't help but bring them home and show 'em some love.If the block doesn't pass muster I'll paint it and put a glass tabletop on it.(or donate it to the Whitehouse for use as a paperweight).
fishhead
Post by 77mali on Wed Dec 10, 2014 10:38 pm
fishhead wrote:Thanks guys,I tend to get all "Charlie Browns Christmas Tree" over scratch-n-dent car parts.I can't help but bring them home and show 'em some love.If the block doesn't pass muster I'll paint it and put a glass tabletop on it.(or donate it to the Whitehouse for use as a paperweight).
How about getting a whole bunch of bad blocks & making donations all over capitol hill as "Boat" anchors? Suspect
Post by Dinomyte on Wed Dec 10, 2014 10:58 pm
fishhead - there was a tiny mark in my block too. Boring it .030 over left little more than a shadow of it. The machine shop here said it would be just fine and it has been. Mine was likely a little bit of rust as the engine I bought to rebuild had been out and sitting for a few years.
I'm with Ray, you'll be OK.
Post by fishhead on Thu Dec 11, 2014 12:44 am
Thanks fellas,I feel better now.While I'm mooching info..Years ago my old machinist wanted the pistons with him when he bored/honed the cylinders.If I don't know how much overbore is required do I let him bore it first and then order the pistons to be used before he hones the final finish?
fishhead
Post by bracketchev1221 on Thu Dec 11, 2014 9:45 am
If it was me, I would wait until you have the pistons, they can measure the bore right now and tell you how far it would have to go over so you can order them. Unless there is a huge defect in the cylinder wall, more than likely it will need to go .030" over. The shop I worked at kind of liked to start on stuff that they could finish. They didn't want to bore it and then bag it and store it until they could proceed again. It was a job for the day, measure the pistons, bore it, wash it, then put the deck plate on and hone it to final size and wash it again.
Street Cred : 14
Post by pila on Thu Dec 11, 2014 10:03 pm
In the old days, many small machine shops used a boring bar that sat on the deck of the block, which didn't account for squareness etc. These days the block is bored while it sits on a mandrel in the main bearing webs. And back then they wanted all the over sized pistons to do an over-bore. Seems like they didn't trust the pistons to be all the same, which was a good idea. So they numbered each piston to match it's bore, with the proper clearance. Even now we can't trust everything to be perfect when we buy it.
Post by bracketchev1221 on Thu Dec 11, 2014 10:48 pm
The shop I worked at still measures every piston and marks them 1-8. That way we could keep track of clearances and weights.
Street Cred : 14
Post by fishhead on Fri Dec 12, 2014 12:32 am
Got it.Thanks much,guys.
fishhead
