Proportioning Valve Relocation with BB and Headers
Post by mc71454 on Sat Jan 03, 2015 5:54 pm
Have any of you guys that have swapped in a BB for a SB, did you need to relocate the Brake Proportioning Valve for header clearance?
I had to on my '71 Monte which was the first year of the combination valve. just moved it up on the frame instead of along the inside rail.
Would like to do that before the motor gets dropped in.
Thanks !
mc71454
Re: Proportioning Valve Relocation with BB and Headers
Post by jerry46765 on Sun Jan 04, 2015 3:49 am
What headers are you using?
Hooker Super Comps will require denting, tweaking, and grinding, but I didn't move prop valve.
Street Cred : 20
Post by marks454ss on Sun Jan 04, 2015 4:26 am
Along with a healthy dose of cussing! And Give Me Beer
marks454ss
Post by mc71454 on Sun Jan 04, 2015 5:20 pm
jerry46765 wrote:What headers are you using?
Will be using Hooker Competitions with 2" Primary Tubes.
They were in my '71 Monte Carlo for 15 years. 540" motor ran 10.30's at 130 mph with them on pump gas and full exhaust. 4000#'s. Would like to recycle them and use on the '75 with 454.
mc71454
Post by jerry46765 on Tue Jan 06, 2015 12:27 am
Well, you are in the best position to answer this question.
You have the headers and the car.
Nine times out of ten, a tape measure will trump BS from the internet.
Let us know.
Thanks -
Street Cred : 20
Post by mc71454 on Tue Jan 06, 2015 2:21 pm
jerry46765 wrote:Well, you are in the best position to answer this question.
Let us know.
Thanks -
Well the engine and trans are not in the engine bay and we have the entire front suspension removed. Hence the reason for the question now before new 454 / TH400 go in.
Yes, I am aware that I could check it out by dropping in the engine/headers combo together for a test fit, which if no one with a BBC sees this post by Friday night and can answer my question, we will have to do. not that big of a deal, and would shed a lot of light on motor mount, header, and steering shaft clearances.
Don't particularly want to move the valve up onto the top of the frame if we don't have to. But if we do, we have to do it with the engine and trans out of the car and my son doing the work with me directing due to my severe back injury and spinal trouble.
mc71454
Post by Bruisr on Tue Jan 06, 2015 5:30 pm
I've done 2 of these swaps. 1. A1974 chevy Malibu, 2. A 1976 GMC Sprint. I had some BB headers from Hedman bought from Summit , I used these headers in both cars. NIETHER car required any special mods. It was a simple drop in. I used both Big Block mounts and small block mounts. The only difference I could tell is the clearance between the crossmember and the oil pan. But either motor mount will work. I DID NOT have to mess with the proportioning valve.
Post by mc71454 on Thu Jan 08, 2015 8:57 am
Bruisr wrote:I've done 2 of these swaps. 1. A1974 chevy Malibu, 2. A 1976 GMC Sprint. I had some BB headers from Hedman bought from Summit , I used these headers in both cars. NIETHER car required any special mods. It was a simple drop in. I used both Big Block mounts and small block mounts. The only difference I could tell is the clearance between the crossmember and the oil pan. But either motor mount will work. I DID NOT have to mess with the proportioning valve.
Thank You !!!
We'll drop her in and see what we get.
mc71454
Post by marks454ss on Fri Jan 09, 2015 7:57 am
My 73 came with a 454 and I had no issues when I installed my Hooker headers other than my big hand making it difficult to put the wire back on the valve after replacing all the lines.
marks454ss
Post by mc71454 on Mon Jan 12, 2015 12:54 pm
marks454ss wrote:My 73 came with a 454 and I had no issues when I installed my Hooker headers other than my big hand making it difficult to put the wire back on the valve after replacing all the lines.
Thanks Mark !
mc71454
Post by 73ss on Tue Oct 20, 2015 7:38 pm
everything fit fine on my 73. Prop valve is in stock location. However, New motor mount stands on the frame did help with some fitment issues on pass side where one of the tubes hit on the lower control arm mount. Pass side was tight with the old mounts.
Street Cred : 10
Post by BBMALIBU on Thu Oct 22, 2015 10:06 pm
I have a 1976 Malibu with a BBC, and I am using 2" Hooker Super Comp header (for a 73-77 Chevelle).
I did not have to relocate the brake prop/combo valve.
However, I recall needing to cut a section of one of the motor mounts, per the instructions.
Although the instructions mentioned denting, I did not need to.
BBMALIBU
