Lugnuts
Lugnuts Empty Lugnuts
Post by ant7377 on Mon Jan 19, 2015 11:20 pm
Hey guys I need some help with this. I bought a new set of wheels for my 77 Monte. Im not sure what lugnuts I need. I know 7/16 X 20 with the washers but how long ? Should the end of the lug nut be flush with the mounting pad of the rim? Or should it be in there a little? I never had a set of aftermarket wheels before so Im not sure and I cant seem to get a good answer. Also any one know where to get a nice set instead of some Chinese junk that going to get rusty? Thanks.
Street Cred : 35
Lugnuts Empty Re: Lugnuts
Post by dynchel on Mon Jan 19, 2015 11:46 pm
Mcgard lug nuts are what you want. Try summit, jegs, amazon etc.  Best quality IMHO.  As far as length goes, as long as they don't protrude further than the wheel you are good.  If they are too long (go to far into the wheel) for whatever reason you can always double the washers...my two front slots have double washers.....probably not the best solution but it works.  What did you get?  Cragers?
Post by ant7377 on Mon Jan 19, 2015 11:51 pm
Centerline qualifiers. So I bought a pack of of lug nuts and the end of it is id say less than a 1/4 inch in there,I guess that is ok? Here is the rims http://www.jegs.com/p/Center-Line-Wheels/Center-Line-Competition-Series-Qualifier-Wheel/1053990/10002/-1
Street Cred : 35
Post by ant7377 on Mon Jan 19, 2015 11:53 pm
http://centerlinewheels.com/wheels_detail.php?mw_id=117&sw_id=948
If I dont like em Ill put em for sale on here first.
Street Cred : 35
Post by dynchel on Mon Jan 19, 2015 11:53 pm
No problem.   Didn't the manufacturer have a lugnut recommendation?
Post by ant7377 on Mon Jan 19, 2015 11:54 pm
Ok great ,thanks
Street Cred : 35
Post by Joe73 on Tue Jan 20, 2015 6:19 am
Ant, I have some of those type of lug nuts on my centerlines. Two different lengths. Your welcome to try what I have. Measure how thick them metal is in the lug nut hole. Maybe its the same as either of my rims and we'll know which we need.
Street Cred : 72
Post by ant7377 on Tue Jan 20, 2015 7:32 am
Ok Joe thanks. I'll try and measure. I think what I bought will be ok,the next size is going to stick out. Will be too long.
Street Cred : 35
Post by Joe73 on Tue Jan 20, 2015 7:39 am
Stick a pencil or something in there for the depth and measure it. Then give me a call.
Street Cred : 72
Post by bracketchev1221 on Tue Jan 20, 2015 7:51 am
Isn't that the lugnut requirement right on the page from the Jegs link? 1/2" mag shank?
Post by ant7377 on Tue Jan 20, 2015 11:29 am
Yeah I saw it last night when looking again. The others list it in the features . Didnt see it before
Street Cred : 35
