speedway upper control arms
my cruck is limited in the amount of positive caster , because if i try to give it more than 2 degrees positive caster the camber goes a lot negative... (after 38 years of abuse , things start to loose its shape!)
so... i´m thinking about using a pair of speedway motors tubular upper arms.. they have "offset" and "strut" types in dyferent lengths , anyone have used this kind of control arms? do you think that using offset arms gives enough caster to minimize my problem??
thanks for your opinions!
Juan
Juan
JKK- G3GM Newbie
