Coil Over Conversions
Page 1 of 1 • Share •
I have searched and searched and found nothing promising. Does any one know if they make a Coil over conversion kit for our cars? I am currently wanting to just do the rear but will be doing the front soon too.
oldstofty- G3GM Member
Re: Coil Over Conversions
oldstofty wrote:I have searched and searched and found nothing promising. Does any one know if they make a Coil over conversion kit for our cars? I am currently wanting to just do the rear but will be doing the front soon too.
http://www.spohn.net/shop/1973-1977-GM-A-Body/Suspension/Shocks-Coil-Over-Kits/Rear-Coil-Over-Kit-QA1-18-Way-Single-Adjustable-Shocks-1964-1972-GM-A-Body-Chevelle-Malibu-GTO-etc.html
http://www.spohn.net/shop/1973-1977-GM-A-Body/Suspension/Shocks-Coil-Over-Kits/QA1-Pro-Coil-System-24-Way-Double-Adjustable.html
- Street Cred : 90
i wonder why QA1 doesnt list those on their website. Is anyone have the rears on their car?
All the 64-72 kits i see the upper mount comes with a plate to bolt in the original location but these do not. Even though they are for 64-77
I know a guy that is having the rear done on his olds. I think it was Speed Tech that was doing them. He did a front and rear. Basically you just have to get the brackets. I will see if I can get in touch with him today to find out if he is finished. I talked to them before and they said they would be offering the kit when finished.
I'm pretty sure Dixie Monte Carlo carries the QA1kit.Correct me if I'm wrong.
fishhead- G3GM Member
i dont see any coil overs on their website
My bad..Although I did find QA1 Coil-Over Conversions in the 2015 OPG catalogue but not a kit.Sorry 'bout that.
edit miller racing has the brackets and can make a combo with the shocks hes in Ohio. Plus QA1 do not offer a coil over for are cars do to low order that's from there rep that i spoke to?
black eyes- G3GM Member
Maybe I'm missing something here...I'm looking at the QA-1 Coil-over conversion shock for 73-77 chevelles offered on page 276 of the 2015 OPGI catalogue.Your choice of single or double adjustable/619.99 and 449.99 per set.
Those dirty dogs..here's a partial description,"Specially designed conical springs come with each set allowing for the use of the factory upper spring pocket,while the lower portion rides on plates with the shock body".
The beginning of the ad says these are "front coilover",nothing mentioned concerning the rears.Dang! It really blows being ignored by the top dogs in the performance industry.
Are you trying for better handling or is straight line performance your goal?
It's a drag car just trying to have some adjustability
If it was me I would skip the coil over idea for the front. If the spring rate in the car is right the only thing you adjust is the shock. You can use a single adjustable shock in the front like the strange s5263. It adjusts extension by the knob and compression is a ratio. Generally in a small tire car unless it's wheel standing high, extension is all that is needed. For the rear, you can go with a coil over, but I think I would like to have them mounted vertically to truly see the benefit. If you have a good spring rate you can use a bolt in double adjustable shock like the strange s5064. A small tire car needs a double adjustable shock to extend and then hold it there. My car has been 1.25 in 60' with a single adjustable front shock and moroso trick spring. The rear uses double adjustable shocks.
» coil id with out markings
» Have a gp3500 modded what is the best coil for maximum depth?
» 4000 & 4500 coil choice?
» Coil Technology is no secret
» Nugget Finder coil packaging- have they ever come in a branded box?
» Power Steering Pump Recommendation
» Autometer 2 5/8" Pro-Comp Ultra-Lite #4484 Vacuum Gauge
» Pro Street design concepts
» Where are you at picture
» 76 Guna , Colorado Springs
» 73 LeMans
