Door Kick Panel / Rocker Panel / Trim Panel Question
Sorry if this has been asked before. I've been searching and searching and can't find anything about this, or I don't know what exactly to search for.
I had my front driverside tire blow on the highway and when it did, it damaged the 6 inch (estimate) piece of chrome along the bottom of the door. This is a piece of chrome that is riveted(?) and double sided taped onto the bottom of the door panel.
I've searched for 'kick panel', 'rocker panel', and 'chrome door trim' but can't seem to find anything on it. I've seen the door skin repair panels online, but I don't think that's what I'm looking for (or is it?).
A. What is this called? B. Can I find a replacement anywhere? C. If no OEM replacement, any suggestions?
Thanks in advance, sorry if this is a noob question.
trudust- G3GM Newbie
Re: Door Kick Panel / Rocker Panel / Trim Panel Question
I dont believe that part is available in the aftermarket. There should not be any double sided tape holding it on. There should be "rivets" protruding from the door skin and plastic tabs about 1 1/2" wide by about 4 1/2" tall slide onto the rivets. The chrome part is held on by the top and bottom edge of the plastic tabs.
Someone on the board should have a pic of the rivets and the tabs.
You will have to find someone selling the chrome trim.
Commonly referred to as "lower rocker moldings, lower door moldings, lower fender/qtr. moldings, etc". Very hard to find a decent used set...and, good luck finding NOS ones. No repros available, either.
Here are your GM Part Numbers for LH side moldings:
- 6258029 (Lwr Fender)
- 8707758 (Lwr Door)
- 8706509 (Lwr Qtr-Front of Wheel Opening Molding)
There is a NOS Lwr Qtr on e-Bay right now for $90 (plus shipping).
Here is what's supposed to hold them on:
http://www.ebay.com/itm/NEW-LOWER-WIDE-MOLDING-TRIM-CLIPS-CHEVELLE-MALIBU-EL-CAMINO-73-74-75-76-77-/371325486853?hash=item5674b94705
Thank you, if anything, at least I have an idea now for what I'm looking for and where to get it. I was just quickly looking behind it, it's not double sided tape, it's the white brackets that I saw.
Just an FYI, I gave up looking for this about a year ago after 5 years. The only set I ever saw was on e-bay and sold for about $1200. That was all 6 pieces NOS still in the packaging with clips.
There was a company that made a "reproduction" but it was a chromed piece of metal stuck on with 3M adhesive and didn't have the contours that OEM moldings do so it wouldn't fit right at the front or back.
Last edited by Dinomyte on Tue May 12, 2015 9:11 am; edited 1 time in total (Reason for editing : add info)
Dinomyte- Donating Member
That piece is stainless steel, is it not?
Depending on how badly damaged it is a good stainless guy might be able to repair it. I've got a guy local to me who is a miracle worker if you get desperate.
K
K
Keith Seymore- G3GM Member
If it's badly mangled and you can't find anything, I could probably get you one to get by. Would have typical "road rash" (you know...where it looks like it was scoured by a sand blaster) and some shallow dings/dents/creases.
Saw this one today, will be going back this Wednesday
Big thanks to Orange Juiced for keeping his eyes peeled for me while he hits the yards. I need to make an edit to my post however. I was posting without thinking and accidentally posted that i needed driver's side rockers. I'm actually in need of passenger side front and door rocker panels.
