console project
console project
Test fitting an Olds console, what do you think?
before
after
before
after
Re: console project
looks good.......................
but why??????????????????????????????????????
Re: console project
I like the design of the olds shifter better.
Re: console project
can you put the olds shifter in the chevy console?
Re: console project
No, the Olds is slightly further back than the chevy and the cable is different enough to have to get another cable.
Re: console project
bigredlaguna wrote:No, the Olds is slightly further back than the chevy and the cable is different enough to have to get another cable.
wow,that sucks. does the olds console bolt to the same locations as the chevy?
Re: console project
Here is how the shifters compare to each other. I lined them up at the point the cable attaches
Re: console project
to bad you could not cut and weld and make the olds fit like the chevy
Re: console project
hey red there is someone at the other place that actually made the chevy shifter work with the olds handle the name escapes me at the moment but it looked killer, and another cut to fit the olds console and made it look real nice same upholstery as the interior on it looked really sharp s well
Re: console project
After looking at my original shifter I think it is what is known as a "his n' hers" shifter. I just tried it and it seems to work like one.
The driver holds pressure to move the shifter handle to the passenger side during upshifts, and the mechanism prevents the shifter from accidentally going into neutral. Did all console cars get this?
Re: console project
1973 454 MONTE wrote:to bad you could not cut and weld and make the olds fit like the chevy
Because of the mechanism inside the shifter that would be difficult at best.
Re: console project
bigredlaguna wrote:After looking at my original shifter I think it is what is known as a "his n' hers" shifter. I just tried it and it seems to work like one.
the console shift i have is the same way so i would be safe to assume so
Re: console project
hi. I have put an olds shifter in my laguna. Hope the pic will work. steve.
laguasteve75- G3GM Newbie
Re: console project
I saw it on your cardomain page. I thought your forum name looked familiar.
Did you have to get a shifter cable for a Cutlass to fit it properly?
