Where to find clutch rod boot for 73-77 chevelle???
Where to find clutch rod boot for 73-77 chevelle??? Empty Where to find clutch rod boot for 73-77 chevelle???
Post by Oldschool454 on Thu Jul 02, 2015 3:53 pm
I've looked around but maybe just not hard enough. Looking for a clutch rod boot for my 76 laguna. Where it goes through the firewall. Got the ac up and working again and sick of the hot engine air coming through the firewall. lol Anyone know where to find one? Thanks a million.
Oldschool454
Oldschool454
Where to find clutch rod boot for 73-77 chevelle??? Empty Re: Where to find clutch rod boot for 73-77 chevelle???
Post by Joe73 on Thu Jul 02, 2015 4:31 pm
You wont find a factory one (I've done 3 worldwide searches). But when your not a factory manual you can use a 70-81 camaro firewall boot. Looks the same as factory but smaller. Just dont make a big hole in the firewall. The camaro one will not cover a factory clutch rod hole.
Street Cred : 73
Post by Joe73 on Thu Jul 02, 2015 4:46 pm
Ok, just took some measurements for you. Factory hole in the firewall is 2 inches in diameter. Boot uses 2 bolts to mount it. Factory boot has 3 1/2" bolt spacing. Camaro boot uses 2 1/2" bolt spacing.
Street Cred : 73
Post by Oldschool454 on Thu Jul 02, 2015 9:22 pm
That's great! Summit sells one for 12 bucks, so looks like I'm in business! I measured the hole in my firewall and it measured between 1 1/4" and 1 1/2" diameter, so sounds like it should cover it no problem. Thanks for the help! It'll be great to finally have the cockpit sealed off. Just in time for this July heat. Thumbs up
Oldschool454
Oldschool454
Post by Joe73 on Fri Jul 03, 2015 1:01 am
no problem.
Street Cred : 73
