Differential cover sealant
Post by SSTOOLMAN on Thu Aug 06, 2015 11:24 pm
Hey guys I got some seepage, whats the best sealant for the diff cover?
SSTOOLMAN
Re: Differential cover sealant
Post by chevellelaguna on Thu Aug 06, 2015 11:30 pm
Never had a problem with just the good quality black or orange sealer in a tube, the orange or red is usually high heat, not really necessary. Also Great Stuff, if you can find it works awesome too!
Street Cred : 16
Post by Joe73 on Fri Aug 07, 2015 8:07 am
I agree, great stuff is actually that. If your using a paper gasket I'd use some Permatex Ultra Black on both sides of it. JUST A THIN SMEAR on each side. No need for it to squeeze out and make a mess.
If you dont want to use a paper gasket, then I would use some Ultra Black. Run a bead around the perimeter and around each bolt hole. Let it set up the required time and put your cover on.
If your putting on a girdle style cover then no gasket at all. Just some Ultra Black all around. Like the pic below.
Street Cred : 68
Post by SSTOOLMAN on Fri Aug 07, 2015 10:19 am
I thought Great Stuff is the insulating foam you use around the house...
Do you mean the sealant Permatex gasket maker called the Right Stuff?
SSTOOLMAN
Post by thatfnthing on Fri Aug 07, 2015 12:00 pm
SSTOOLMAN wrote:I thought Great Stuff is the insulating foam you use around the house...
Well, it's a closed cell foam, so it would probably work. Messy, though. Smile
Street Cred : 54
Post by dynchel on Fri Aug 07, 2015 2:46 pm
This is what you want. Napa sells it
