proper re-install technique 73 SS front bumper?
G3GM :: G3 Tech :: Body
proper re-install technique 73 SS front bumper? Empty proper re-install technique 73 SS front bumper?
Post by clanceman427 on Tue Aug 18, 2015 10:09 pm
I read thru all 6 pages of the Body section, did find a thread on 73 Chevelle front bumper removal procedure, but now I'd like to know the proper re-install of a 73 Chevelle front bumper. Currently I have the urethane corner fillers bolted up to the front fenders and header panel, and also the under-headlight grille strips. And then I have the hard plastic center filler piece bolted to the bumper. Tried unsuccessfully to re-install it. (see Picture).
Should I not have those corners pre-bolted to the body? Seems now that I'm thinking about it (and catching my breath and icing my thighs and back Shocked ) maybe the proper procedure is to take those corners out completely, start the bumper on in a rough position, get a few horizontal bolts started, and then weave the urethane corners and grille strips in? My brain said stop before I tear one of the bumper fillers and tear a hernia. Laughing Any re-assembly tips appreciated!
proper re-install technique 73 SS front bumper? Imag0628
proper re-install technique 73 SS front bumper? Empty Re: proper re-install technique 73 SS front bumper?
Post by Limey SE on Wed Aug 19, 2015 12:35 am
clanceman427 wrote:I read thru all 6 pages of the Body section
Street Cred : 91
Post by clanceman427 on Wed Aug 19, 2015 8:37 am
Thanks Anthony! I'll do it that way next attempt
Post by thatfnthing on Wed Aug 19, 2015 8:49 am
I've found this to be a lot easier, and less damaging to the fillers:
1. Take the bumper fillers off
2. Place them loose in the bumper
3. Put the bumper back on
4. Bolt up the fillers
Street Cred : 58
Post by clanceman427 on Wed Aug 26, 2015 12:12 am
Guys, thanks for the tips. I was able to mount the bumper with 2 bolts, and then weave the urethane corners in, then the grille-ette from the side, tighten the grille-ette bolts, do the same on the other side, then final position and tighten all 8 main bumper bolts, and finish by tightening the lower braces for holding to the fender with the 3 nuts. Nice!
proper re-install technique 73 SS front bumper? Imag0710
Post by Limey SE on Wed Aug 26, 2015 8:34 am
Nice coming together good looks like
Street Cred : 91
Post by clanceman427 on Wed Aug 26, 2015 3:29 pm
Thank you Anthony!
