Window adjustment 77 elky
Just redid the weatherstripping and the window won't line up. I'm fighting a few things like a rotted out lower regulator bolt hole, worn rollers, and bad door hinge pins. Thinking I'm missing a bot to loosen since the back won't go into the right position no matter what adjustment I try to make
braunicus- G3GM Newbie
Re: Window adjustment 77 elky
That is a patience trying project. All I can say is take your time & good luck.
Thanks for the quick reply and information
Window Adjustment
PostPosted: Mon 24 Aug 2015 - 0:13 by Mcarlo77
Obviously, you have a few issues that could affect the alignment. But, here are the instructions per the Chevrolet Service Manual for adjusting front to back.
WINDOW TILTED
-Loosen two bolts (A) and adjust by rotating glass until a constant distance is gained between front edge of glass and the windshield pillar. Retighten bolts A.
WINDOW TILTED
» Door latching-is my car needing adjustment?
» Quarter window/Opera window trim removal
» Headlight adjustment springs
