Bolt in axle
Bolt in axle
Post by ant7377 on Tue Aug 25, 2015 9:31 pm
Anyone have a good set of these or a source to get new ones? Ive had this friggin vibration and after a bunch of parts and 2 new tires (they helped) the vibration is still there so I broke down and took it to a shop. He put it on the alignment rack with wheels off the ground and ran it and the left axle has runout. Id like to replace them both. Its a 8.5 rear but with the olds bolt in axles im sure we are all familiar with.
Street Cred : 34
Re: Bolt in axle
Post by chevellelaguna on Tue Aug 25, 2015 11:25 pm
Why not pull the axles and have the face trued up at a machine shop? Depending on how much runout there is. Might end up with used ones that are also bent! 100
Percent certain that it's the axles and not anything else like bad motor/trans mount worn u joints bent driveshaft, missing weight, etc?
Street Cred : 16
Re: Bolt in axle
Post by ant7377 on Tue Aug 25, 2015 11:29 pm
Its something back there . He says you can see it . It isnt much but with a small tire on it you can see it. Joe and I worked on it a while back and we saw something there too. Id like to buy new ones but I dont see them anywhere,just c clip ones. I might not be looking in the right place though.
Street Cred : 34
Re: Bolt in axle
Post by ant7377 on Wed Aug 26, 2015 5:24 am
Not a u joint I had the driveshaft balanced and everything checked out good.
Street Cred : 34
Re: Bolt in axle
Post by Joe73 on Wed Aug 26, 2015 7:07 am
Ant, I havent stumbled upon bolt in axles. Only the normal C clip ones. A good option might be getting some "ten factory" axles like I did and putting some C clip eliminators on them. Then they will bolt in.
Just a thought.
Street Cred : 70
Re: Bolt in axle
Post by ant7377 on Wed Aug 26, 2015 7:14 am
Joe. Will the c clip eliminator bolt to the stock place on the backing plate? What about the bearing?
Street Cred : 34
Re: Bolt in axle
Post by Joe73 on Wed Aug 26, 2015 8:02 am
C clip eliminators have the bearing and seal mounted together and get pressed on the axle. Then they bolt onto the backing plate bolts with longer bolts. Look in different manufactors of them and see what it says in the instructions. Figure its a good option.
Street Cred : 70
Re: Bolt in axle
Post by ant7377 on Wed Aug 26, 2015 8:05 am
Yeah . Thats a really good option. What ones did you use?
Street Cred : 34
Re: Bolt in axle
Post by Joe73 on Wed Aug 26, 2015 8:25 pm
I'm not running them. I looked at them quickly when I rebuilt my rear but just bought the ten factory axles and installed them.
Street Cred : 70
Re: Bolt in axle
Post by ant7377 on Wed Aug 26, 2015 9:16 pm
So ten makes the bolt in axles? Didnt see them or do the ones listed for 8.2 work. I know they are interchangable but the length im not sure about.
Street Cred : 34
Re: Bolt in axle
Post by Joe73 on Wed Aug 26, 2015 9:54 pm
I didnt see ten.factory bolt in axles but if they are the same then u could put eliminators on them. Maybe call them. Does rockauto have anything?
Street Cred : 70
Re: Bolt in axle
Post by ant7377 on Wed Aug 26, 2015 9:59 pm
I think I found them. Toms differentials. Says 73-77 Elcamino and 73-79 BOP. I will call tomorrow.
Street Cred : 34
Re: Bolt in axle
Post by brownbomber77 on Fri Sep 18, 2015 9:45 am
Most Buick Olds Pontiac axles were all bolt in. Might be easier to find one out of a Cutlass...they're all over the place.
brownbomber77
Street Cred : 4
Re: Bolt in axle
Post by ant7377 on Fri Sep 18, 2015 9:47 am
I got them from west coast differential made by nitro. They worked out good! Unfortunatly there isnt Cutlass' all over around here anymore.
Street Cred : 34
Re: Bolt in axle
Post by brownbomber77 on Fri Sep 18, 2015 10:19 am
I couldn't find them on their website....do you have a link?
brownbomber77
Street Cred : 4
Re: Bolt in axle
Post by ant7377 on Fri Sep 18, 2015 10:35 am
http://www.justdifferentials.com/mobile/Product.aspx?ProductCode=AXG1254369
It was these guys in washington state. Sorry got it mixed up I was searching for them and had many in my favorites.
Street Cred : 34
Re: Bolt in axle
Post by ant7377 on Fri Sep 18, 2015 10:36 am
How I found them was I got the GM Part # then searched google with that.
Street Cred : 34
Re: Bolt in axle
