Right side front bumper spacer for 1973 chevelle
G3GM :: Classifieds :: Wanted
I'm looking for a spacer that goes between the front bumper and the body
John brown- G3GM Member
Re: Right side front bumper spacer for 1973 chevelle
The inner filler?
I guess is there an inner and an outer filler?
Oh, the urethane filler. Replica plastics makes fiberglass versions of those if you can't find a used set.
I didn't know that. This forum has been a lot of help.
There are 2 outside sections made of a flexible urethane and a center section that is a harder plastic. Used outside sections are available from time to time on ebay. the center section is a tough find they are always cracked and usually hard to repair permanently. I bought the three sections from replica plastics, they are fiberglass. They needed modifications to fit correctly so I didn't use them. I ended up buying a NOS center filler from a member here ($300) and 2 outside sections from ebay. If you are good at fiberglass mods I will sell you my 3 piece set for $50 plus the ride. (paid $150) I know an other member had used them on a Monte I think and they got good results, but they will need mods/fitting (2 outside pieces) center is pretty straight forward.
SSTOOLMAN- Donating Member
I have the center and the left side so I was hoping to just get that but I appreciate the offer and I will keep it in mind.
John
John
OK, I have 1 factory side, I cant remember if its left or right. Ill check if your interested?
I didn't know the center section on a '73 is plastic. On a '74 its steel.
Sure let me know!
Heres the Middle section if you need a better one ?
http://www.ebay.com/itm/1973-CHEVROLET-CHEVELLE-COUPE-SS-454-FRONT-BUMPER-PLASTIC-FILLER-PANEL-DAMAGED-/141653875791?hash=item20fb3a9c4f&vxp=mtr
I've got a god middle but I appreciate the offer.
John
John
I just looked and I have a extra factory urathane passenger side front bumper filler. PM me if your interested.
» 1973 chevelle bumper vs 1974 chevelle bumper
» 73 Chevelle Front Bumper Filler
» 1973 Chevelle SS Rear Bumper
