73 SS Saginaw M20 reverse lockout rod tracings here
Post by clanceman427 on Thu Oct 15, 2015 9:38 am
Hello, since I'm in the middle of replacing my clutch and rebuilding my transmission, I traced the reverse lockout rod in case anyone needs it. I know Joe was looking for it, and so here are a few photos of the rod. This rod goes from the transmission's reverse lever to the bellcrank bolted to the frame over the brake distribution block/proportioning valve. The rod is a simple straight piece, no curves to it, but the rod ends are at angles, not 90. If anyone would like a fax or a photocopy mailed to them, just let me know. I will also trace the bellcrank to steering column rod as well.
Re: 73 SS Saginaw M20 reverse lockout rod tracings here
Post by clanceman427 on Thu Nov 26, 2015 2:08 pm
and now here are a couple photos of the backdrive bracket, with a tape measure, and also a photo of the tracing I now have for the upper linkage (steering column to backdrive bracket. Let me know if you'd like a copy of the tracing. Joe, You will receive copies of all the tracings in the mail.
