door jamb switch wiring help
door jamb switch wiring help Empty door jamb switch wiring help
Post by bitterfitter on Mon Oct 19, 2015 10:56 am
I am hoping someone here can help me with getting these wired correctly.  I know they all worked when I took the car apart for painting.  At my passenger side door I have a white wire that I believe went to the door switch.  I also have a dark blue wire but I am not sure if that goes to the switch or not.
door jamb switch wiring help Passen10
On my drivers side I have 2 white wires coming together in 1 spade connector.  I am pretty sure this was connected to my switch.  I also have a black wire with a purple stripe that is molded to one of the white wires.  This one has no end on it now.  I am not sure if this is supposed to also go to the switch. door jamb switch wiring help Driver10
I have looked at the schematic but it is not real helpful with running these.  Anyone able to help?  Or have any ideas?
bitterfitter
door jamb switch wiring help Empty Re: door jamb switch wiring help
Post by Joe73 on Mon Oct 19, 2015 11:02 am
I just checked mine.
Pass side is two white individual wires one on each side of the switch.
Drivers is two white wires on one spade and a black with purple stripe.
Same as yours.
Street Cred : 72
Post by Mcarlo77 on Mon Oct 19, 2015 11:17 am
That dark blue wire most likely went to the rear speakers.
Street Cred : 68
Post by bitterfitter on Mon Oct 19, 2015 9:12 pm
I only have 1 white wire on passenger side. I will have to check again but pretty sure just one. I assume the white and black/ purple are tied together at the switch. I also assume the switches are breaking the grounds to the dome light. Just checking because I am wiring up a late model rear view mirror with lights and also a Dakota Digital retained power accessory.
bitterfitter
Post by Mcarlo77 on Mon Oct 19, 2015 9:30 pm
One white wire on the passenger side switch. And yes, the switches break ground to the dome light and underdash courtesy lights
Street Cred : 68
Post by bitterfitter on Mon Oct 19, 2015 9:33 pm
Thanks. I thought I was going crazy.
bitterfitter
