Need the Cable for Shift indidcator for console shift
Need the Cable for Shift indidcator for console shift Empty Need the Cable for Shift indidcator for console shift
Post by Limey SE on Wed Oct 28, 2015 5:12 pm
Yes I need this when I changed columns out I found out why it didn't work, LOL It attach's to the column part that rotates when Shifted or does anyone have a verified measurement so I can make one ??
Need the Cable for Shift indidcator for console shift 12527912
Street Cred : 91
Need the Cable for Shift indidcator for console shift Empty Re: Need the Cable for Shift indidcator for console shift
Post by 73ss on Thu Oct 29, 2015 8:19 pm
the piece that goes from the tranny to rotate the column mechanism should be a metal linkage. Much like a regular column shifted automatic. Are you talking about the shifter cable itself?
Street Cred : 10
Post by Limey SE on Thu Oct 29, 2015 8:55 pm
Nope I need the cable that moves the Indicator in the dash
I need this cable
Need the Cable for Shift indidcator for console shift S-l500
Street Cred : 91
Post by 73ss on Thu Oct 29, 2015 9:33 pm
gotcha. My indicator is on the console itself.. If you can get a part # you can google it., someone out there probably has a nos. I've found quite a few parts this way. Might try gm wiki.
Street Cred : 10
Post by Limey SE on Thu Oct 29, 2015 9:57 pm
yea most 73's were on the console, I would prefer it that way but would have to change all kinds of stuff LOL
I wonder if this Camaro one could be adapted to the Console shift plate ?
Street Cred : 91
Post by Mcarlo77 on Sat Oct 31, 2015 1:00 pm
Tried to find one for you yesterday while out at a yard, Limey. No dice...all were gone. Probably find one at the larger yard if you aren't in a big hurry. BTW...I believe the column shift and floor shift cables are the same.
Street Cred : 68
Post by Limey SE on Sat Oct 31, 2015 2:23 pm
yea No hurry Steve she is packed away till Spring anyways, Unless we get that Godzilla El Nino there talking about and then who knows what will happen, Just cant be from a 73 as there a console mounted one, I WOULD TAKE THAT ONE IFYOU FIND one, BUT would need the shift indicator,cable and the shifter cover
Street Cred : 91
