Comp Cams 2 piece timng cover
Comp Cams 2 piece timng cover Empty Comp Cams 2 piece timng cover
Post by Joe73 on Tue Nov 03, 2015 8:08 am
Anyone run a 2 piece aluminum timing cover ? http://www.summitracing.com/parts/cca-210
I've been looking at them for some time. I have a brand new polished 1 piece cover in my box of goodies but I like the idea of not disturbing the oil pan gasket when removing the timing cover.
I like the cloyes one as well but it doesnt allow you to remove your cam, only adjust it.
I've read good things about the comp cams one.
Anyone have one for sale ??
Street Cred : 73
Comp Cams 2 piece timng cover Empty Re: Comp Cams 2 piece timng cover
Post by bracketchev1221 on Tue Nov 03, 2015 8:23 am
Its a good idea, but I think if it was me, I would buy the right cam the first time and use a stock cover. Use the money from buying the 2 piece cover and have a custom cam ground for the application.
Post by thatfnthing on Tue Nov 03, 2015 9:33 am
I'm using a similar 2-piece I scored used on ebay for $75.00.  No name, but it's a solid aluminum piece (doesn't flex like the stamped steel 1-piece units), and I bought it for exactly the reason you stated -- not having to drop the f!@#ing oil pan if I need to swap cams, gears or timing chain.  Whole face comes off like the Comp Cams one, unlike some others where they only give you access to the cam itself.  The biggest issue I had was fashioning a timing tab for it -- since I got it used, it didn't have one.
Street Cred : 58
Post by Limey SE on Tue Nov 03, 2015 10:57 am
Joe73 wrote:Anyone run a 2 piece aluminum timing cover ?    http://www.summitracing.com/parts/cca-210
 Joe here ya go Man was just browsing them last night also
http://www.ebay.com/itm/Comp-Cams-Billet-Aluminum-2-Piece-Timing-Cover-for-SB-Chevy-NHRA-IHRA-IMCA-SCCA-/151820416766?hash=item235933b6fe:g:AUIAAOSw37tV-ucD&vxp=mtr
Comp Cams 2 piece timng cover S-l1600
Street Cred : 92
Post by Joe73 on Tue Nov 03, 2015 11:53 am
Thanks limey. I have my eye on a brand new one fkr 150. Just have to see.if the guy will ship.
Street Cred : 73
Post by BBMALIBU on Wed Nov 04, 2015 5:18 pm
bracketchev1221 wrote:Its a good idea, but I think if it was me, I would buy the right cam the first time and use a stock cover.  Use the money from buying the 2 piece cover and have a custom cam ground for the application.
X2
BBMALIBU
BBMALIBU
Post by Joe73 on Wed Nov 04, 2015 6:02 pm
I agree a custom cam would be the way to go to pull any combination together. I still may go that way and not use the cam I have waiting.
I just bought the cover. Should have it in a few days.
thanks guys.
Street Cred : 73
