Weatherstripping advice
G3GM :: G3 Tech :: Body
Weatherstripping advice Empty Weatherstripping advice
Post by bitterfitter on Wed Nov 04, 2015 9:57 pm
So I am at the point of installing weatherstripping and I was looking over what I have. I see how the roof rail w/s fits into metal pieces that screw onto the car. Is there a trick or technique to installing this w/s properly? Kinda looks like I mount the metal strips to the car with screws and w/s adhesive behind it. Then the w/s gets more adhesive and some how gets pushed into this metal strip. This is where I am unsure of the easiest way to do it? Any advice from those who have done it?
bitterfitter
Weatherstripping advice Empty Re: Weatherstripping advice
Post by Joe73 on Wed Nov 04, 2015 10:16 pm
The metal pieces get screwed to the car with this under them as a sealant.  http://www.ebay.com/itm/201033833139?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Then the weatherstrip just gets pushed into the grooves.  I use a credit card or a wood paint stick to push it in.  Pretty easy actually.
Street Cred : 72
Post by Limey SE on Wed Nov 04, 2015 10:21 pm
subscribed I have to mine as well
Weatherstripping advice 12527912
Street Cred : 91
Post by bitterfitter on Wed Nov 04, 2015 10:30 pm
Is it easier to insert one side or the other of the weatherstripping ? Almost looks like the outside should go in first and push in the inside edge last.
bitterfitter
Post by chevellelaguna on Thu Nov 05, 2015 4:52 pm
Use some soapy water as well, it'll slip in like a champ. Like you said slip one edge in first and work the opposite side in with a credit card or plastic bone.
Street Cred : 16
Post by bitterfitter on Thu Nov 05, 2015 5:28 pm
Does the weatherstripping get adhesive to hold it into the metal strip? It looks like it should but wouldn't the soapy water affect this?
bitterfitter
Post by Mcarlo77 on Thu Nov 05, 2015 6:50 pm
I know they used adhesive at the factory. I installed some NOS w/strips this summer and the fit was so good that I didn't bother with the adhesive. It holds just fine...but, have to admit there was a method to my madness as I wanted them to be removable when time came to paint the car.
Street Cred : 68
Post by Joe73 on Thu Nov 05, 2015 7:15 pm
I dont recall any adhesive when I replaced mine in the 80s.
Street Cred : 72
Post by chevellelaguna on Thu Nov 05, 2015 8:55 pm
There was adhesive from the factory, similar to 3M weatherstrip adhesive. As long as you're not drowning your car with soapy water, couple drops diluted in a spray bottle is sufficient, again you're just spritzing the weatherstrip, not hosing it down. I fail to understand that the w/s won't go into the channel easily, hook one end in , and even using your thumb should force the rest into the groove. The use of the W/S adhesive will prevent the w/s from getting pulled down by the glass on a hot day.
Street Cred : 16
Post by bitterfitter on Thu Nov 05, 2015 10:11 pm
It may go into the track easily. I haven't begun to install these yet. Just looking for a heads up.
I just finished the vinyl top around the skyroof and installed that w/s. Now I just have to wait for the foam tape that was mentioned above. Then these pieces go on.
bitterfitter
Post by chevellelaguna on Thu Nov 05, 2015 10:25 pm
Awesome, like you said good to be prepared for possible issues that may arise.
Street Cred : 16
