Coil spring interchangeability
alowerlevel
tropdeprojet
brownbomber77
Does anyone have the lowdown on springs and other stuff for our chassis? I am looking around for options on suspension parts like drop spindles, springs, control arms, and other parts and I see that the choice of springs available to us is very slim. I also can't find drop spindles that would be compatible.
I know there are parts out there but (and though this is a future endeavour) I can't afford $1000 for QA1 coilovers. I have seen our cars get nice and low and handle amazingly but I wonder if the older A body springs and spindles would fit.
Another thought I had was that while I had my engine bay apart I got a good look at my crossmember and A arms and was surprised at how they look exactly like my S10's. I wonder if parts would interchange.
SonOfTheGrim- G3GM Member
Spindles
Spindles from Summit:http://www.summitracing.com/search/year/1974/make/chevrolet/model/malibu/part-type/spindles?N=4294950312%2B4294951398%2B4294950343%2B4294945825&PageSize=100&SortBy=Default&SortOrder=Ascending&keyword=spindle
jerry46765- Donating Member
Re: Coil spring interchangeability
Most b-body parts (caprice, impala ss) will work. And the front upper & lower arms, springs and spindles are the same as 2nd gen fbody(70-81) per the hollander interchange manual.
Also theres more and more companys out there starting to make aftermarket suspension parts for our cars, check out
http://scandc.com/new/catalog/49
http://www.globalwest.net/1973-77chevelle-elcamino-montecarlo.html
http://umiperformance.com/catalog/index.php?main_page=index&cPath=379
http://www.detroitspeed.com/1973-1977-A-Body-products/1973-1977-a-body-products.html
http://www.speedtechperformance.com/index.cfm/page/ptype=results/category_id=18/mode=cat/cat18.htm
alowerlevel- G3GM Member
My buddy used IROC springs to lower his 77 Cutlass Salon almost 2 inches. Looks badass
brownbomber77- G3GM Member
I used 4 coils 2 inch drop from Springtech at a good price. You can have it in blue or dark grey!
tropdeprojet- Donating Member
This is great information; exactly what I was looking for! You guys are awesome.
So I have been looking around at impala/caprice parts thinking they'd be pretty cheap compared to everything else but DAMN that stuff is expensive! $450+ for a set of spindles?! $250+ for springs?! I guess the market is more for chromed and bagged cars and those guys get pricy.
Then I looked around for camaro stuff but it's all performance upgrades so more $$$. I'm looking on craigslist for some deals but nothing yet. The good thing about the F body stuff is that there is plenty of it around.
I may not be saving any money by getting non-A body parts in the end. Oh well, just a thought.
I did look into SpringTech but couldn't find a direct site and the sites I found with their products didn't have anything for my car.
Maybe they are no more available. I found my bill from 2014. They was sold from Suspensionmax on eBay for 179$ for the four sets.74-75-76 chevelle lowering spring.
What are you looking for? Drag racing, handling, or just replacement parts?
I'm not a racer but I do want to improve handling and to work on the boat feeling that my El Camino had (since I've never actually driven the chevelle) and I like low but not stupid low.
I have to ask: I was looking around Google and found a few things about using Jeep springs on earlier chevelles? Is that right?
Maybe you also want to read this thread if you haven't already: www.g3gm.com/t6388-dse-lowering-springs-thoughts
I read through that thread. Very good info about springs and lots of good pictures to give a good idea of what you are getting. I think that this picture in particular is a perfect stance.
I also found a thread on another Chevy site that suggested that any earlier chevelle rear springs would drop the rear of our cars by 2". Can anyone confirm this?
Almost too low but not. Those are also bigger wheels than I have so my fenders wouldn't be that full. Seems like that is 2" front and 1.5" rear.G3NUT wrote:Dse Springs rides nice not to stiff.BK-75 wrote:Anyone using Detroit Speed Equipment lowering springs (F-2 in/ R-1.5 drop) that can provide me with some real world feedback.
Any help you can provide would be appreciated!
Thanks!
I would get a Moog part number for an earlier chevelle from RockAuto.com.
Then go to http://www.moogproblemsolver.com/suspension/coil-springs
left side of the page and click "coil spring specs". Its a PDF file.
Then find that Moog part number and compare it to other part numbers. All the specs on all their springs are right there and easy to find.
Ok so I did go to Rockauto.com and found those part numbers BUT it turns out that rockauto links to all of Moog's specs in their [Info] popup. So I just found the springs for my car here and the springs for a 1972 Chevelle here and it turns out they are in fact basically exactly 2" shorter than our stock springs. The spring rates are comparable. Load rate is a bit less.
That is something I think alot of people would like to know. Now I just need to look through all the front springs for a similar find and I'll be in business!
Ok so I found these and had to ask about them- click
Anyone ever used these on anything? Pretty sure it's an off road type of thing.
I experimented with a set of 2nd gen rear springs in my 73 it sat kind of low.but you couldn't put anyone in the back seat. It would bottom out.
G3NUT- Donating Member
I was wondering about that with the lower load rating, making it too bouncy or springy in the back.
i got the 68-72 abody rear springs with 20x10 rims it set the back down an inch im using two inch drop hotchkis springs on the front for a second gen camaro looking to get the hotchkis stock ride height rear springs for the 68-72 abody to match the spring rates rides well now just want amore sportier feel out back. also the stock sway bar that bolts into the bottom of the control arms is a weak link i ripped all four bolts so i would definetly recommend the newer style caprice rear sway bar or the aftermarket side mount. also i have the 95 impala rearend in right now too and everything has fit perfectly
McCauley5983- G3GM Enthusiast
