Need like yesterday for a friend
G3GM :: Classifieds :: Wanted
Page 1 of 1 • Share •
THIS IS FOR A LOCAL FRIEND needs it like yesterday he is paypal ready and did I say he needs it badly
still am in need of the little spring that keeps pressure on the automatic trans linkage rod. (the spring that is missing in my pic) I took my car apart a year ago and cant find my spring.....
- Street Cred : 90
Re: Need like yesterday for a friend
Did he try a local hardware store? By the nuts and bolts they usually have draws with all kinds of cool stuff in there. They definitely carry springs of all sizes and diameters.
- Street Cred : 71
he doesn't remember what size it is ??
- Street Cred : 90
is he still looking for the spring? I found my old one and was going to hit the hardware store some time and find a new one. when I do I can give the info for what the new one is and the measurements of the old one.
riddick75- G3GM Member
Yes you can fwd that I will pass it on to him
- Street Cred : 90
He likely needs that cone-shaped white plastic end piece that retains the spring on the frame bracket too...
Losing little parts is part of what we do !!
Thanks Guys I fwd all the Info
- Street Cred : 90
Thank you my friend, But he has the Linkage just needed that spring
- Street Cred : 90
ok for the spring the measurements are 5/8" diameter and 2 3/4 length. the wire gauge is between 0.54 or 0.63 , 0.41 was too weak. still working on finding the exact spring, menards by me didn't have it so Ill try a real hardware store tomorrow. 0.63 seemed like a good tension compared to my old one but that was 3/4 diameter and the tighter coil might make it stronger as well. Hopefully Ace will have a better selection like they have for everything else I have needed.
- Street Cred : 90
» FC Halifax yesterday
» my friend and a mine shaft
» Battle of the Boards! by Ryerson University
» Some more of that "Change" we're getting nowdays! I was sent this by a friend.
» Fallen Soldier. A devoted husband and father, and my friend.
» Power Steering Pump Recommendation
» Autometer 2 5/8" Pro-Comp Ultra-Lite #4484 Vacuum Gauge
» Pro Street design concepts
» Where are you at picture
» 76 Guna , Colorado Springs
» 700r4 trans problem?
» 73 LeMans
