'74 El Camino "Project Badass"
Page 3 of 7 Previous  1, 2, 3, 4, 5, 6, 7  Next
'74 El Camino "Project Badass" - Page 3 Empty Re: '74 El Camino "Project Badass"
Post by builtnotbought on Tue Feb 09, 2016 3:24 pm
Let's continue the story.
It was time to assemble the rest of the parts together to make a body look like a car again.
I was taught here on forum a new abbreviation - p.i.t.a, so it was a real pita to make door fenders and hood be aligned together.
We worked in six hands, first re-aligned doors to the body because they were not aligned well in the paintshop. Then fenders. They didn't want to stay in the right place to make perfect same clearences with doors. I don't know why, may be because of new body bushings + new radiator core bushings, may be because body has a lot of room to move each side on bushings...After million attempts of moving them we had some succesful result.
The hardest part was the welded hood. It was welded with all rules with saving it's geometry while cutting but it didn't want to fit anyway in the front between the fenders and clearences of both sides going to doors became larger and larger.
In the middle of the fenders on each side hood had a real bend causing lardge gaps with fenders. A lot of playing with hood hinges that came out to be very flexible and it took it's place on car. The flexure on the hood in the middle along the fenders still exists when it's hold with the latch because hinges are trying to open it always. Hinges are turned to their lower position on the rear side. If moving rear side of hinges up, the flexture I think will dissapear but the gap on the rear part of the fenders and hood will grow.
Besides that I bought all new rubber hood bushings but if installing any of them (side, rear) gaps on sides of the hood become enormous. I think all new reproduction bushings are very big comparing to stock. Now I have only two front bushings in.
How did any of you guys solve this bushing problem? I don't have most part of old bushings to reinstall them.
One more strange thing is that front part of the car (lights housings and upper part of grill) don't want to align with grill perfectly.
So that's what I got in the end of a nightmare.
'74 El Camino "Project Badass" - Page 3 49_zpspnmrim59
builtnotbought
builtnotbought
Post by Mcarlo77 on Tue Feb 09, 2016 6:02 pm
thatfnthing wrote:IIRC the door panels had a waxed kraft paper layer over the metal door frame, then a padded jute (kind of like thick felt) layer over that, then the interior door panel.  The first layer (paper or plastic) would be a moisture barrier to keep water out of the padding.
Little late to the party, but found this photo of the factory door insulation you guys were talking about.  As described, it was a kraft paper glued to the backside of the padding.
'74 El Camino "Project Badass" - Page 3 Doorin10
Street Cred : 68
Post by builtnotbought on Wed Feb 10, 2016 6:21 am
Not late, right in time! Thank you
I think it's the only one photo in web of this insulation on door )
builtnotbought
builtnotbought
Post by Hs1973 on Wed Feb 10, 2016 3:30 pm
Remember these cars where not at all straight from the beginning. I needed to use alot of shims here and there to get my fenders sitting right. On top of that, the hood hinges usually is worn in the bushings. All of that together gives alot of problems when aligning the bodyparts. The front support needs to be aligned with shims to give the right amount of gap at the bottom to the doors.
Also i start by aligning the doors first and put in the glass and hardware, and put the weather strip in. And get them to close right. If you align everything with empty doors you get in trouble, the glass and hardware is heavy and will make the doors sag a little, so they need reajusting after installing. Then you risk to have to reajusting fenders again.
The doors are a Real pita to ajust so they close right. And the glass is even worse. So i always install the doors glass and all wetherstrip and ajust it so everything works right. Then i install the frontend sheetmetal.
Is also always restore the door hinges with new bushings and make sure there is no slack in them that will make the doors sag.
I actually considered removing the side impact bar to save some weight, cause the doors are freakin heavy and would open and close more easy If lighter.
Its looking Real good keep it coming.
Street Cred : 12
Post by builtnotbought on Wed Feb 10, 2016 4:08 pm
Thank you for reply!
Yes i rebuilt door hinges with new studs kit, no movement in them.
Yes, shims make alignment easy, the strange thing is that i used less number of shims than car had before restoring )))
Hood hinges are in good shape.
The only problem i have now is new reproduction hood bushings that are too lardge to save alignment as it is.
builtnotbought
builtnotbought
Post by builtnotbought on Tue Mar 01, 2016 2:48 pm
This time - bumpers.
Anyone knows that safety laws played not the best game with bumpers design of this Gen of El Camino.
Sometimes earlier I searched web for solving this problem. Saw several photos where people cutted and welded bumper shocks to push it in but it was no my way.
Saw Holley '74 wagon with modified cutted and welded bumpers, but there were no build photos at all, only one with already welded parts.
I decided, we will try to do better and best. I didn't want to delete bumper's reinforcement and didn't want to cut and weld shocks so after some measurments/fitting bumpers and their reinforcements drove away to my metal man while I sat down with PC and start designing new front bumper holders.
Bumper's covers were sliced in pieces and then welded together in new way, loosing all different holes. Mounting system was changed to welded in studs. An unexpected find after shaving was that factory jack system used small oval holes in bumper Very Happy
'74 El Camino "Project Badass" - Page 3 1_zpsn41r8r3k
'74 El Camino "Project Badass" - Page 3 2_zpswppjdvob
'74 El Camino "Project Badass" - Page 3 6_zpsl0ifk84k
'74 El Camino "Project Badass" - Page 3 5_zpsnbzqc2kg
'74 El Camino "Project Badass" - Page 3 4_zpsa9ztwry2
'74 El Camino "Project Badass" - Page 3 3_zps9kls4zlf
'74 El Camino "Project Badass" - Page 3 7_zpsfohfor68
'74 El Camino "Project Badass" - Page 3 8_zpsm7rvcrfy
'74 El Camino "Project Badass" - Page 3 13_zpsuru5pxuv
'74 El Camino "Project Badass" - Page 3 9_zpsps5vu1pt
'74 El Camino "Project Badass" - Page 3 10_zpstjbq8fma
'74 El Camino "Project Badass" - Page 3 12_zpssltbroyw
'74 El Camino "Project Badass" - Page 3 11_zpsxi3xhglg
Trying to fit new width.
'74 El Camino "Project Badass" - Page 3 14_zpslqzrl7jb
'74 El Camino "Project Badass" - Page 3 15_zps8rgwijkc
'74 El Camino "Project Badass" - Page 3 16_zpskonkv4aa
New front holders were laser cutted and welded toghether with the help of my friend, now they are about 11-12 cm length from flange to flange.
'74 El Camino "Project Badass" - Page 3 17_zpso7d2fgxj
'74 El Camino "Project Badass" - Page 3 18_zpscpimjukk
'74 El Camino "Project Badass" - Page 3 19_zpsiwzlbpqp
Rear bumper holders got new longer bolt grooves to push bumper in.
F/R bumper's reinforcements lost their corners to fit new covers.
Plastic bumpers inserts were cutted a little to fit.
'74 El Camino "Project Badass" - Page 3 21_zpsjolo4kvr
Metal inserts were not touched for now.
I don't remember now but I think rear bumper was narrowed about 2.5cm on each side, front I think about 1.5cm on each side.
First I thought of shaving USA plate place but then gave up this idea. Too many shaved panels on car is not good too.
Fitment with new F/R holders
'74 El Camino "Project Badass" - Page 3 28_zpsnwdzhe9m
'74 El Camino "Project Badass" - Page 3 27_zps2wji9unv
'74 El Camino "Project Badass" - Page 3 26_zps04bhqqmq
'74 El Camino "Project Badass" - Page 3 25_zpsx9qjg6nm
'74 El Camino "Project Badass" - Page 3 24_zpszd9uqyos
'74 El Camino "Project Badass" - Page 3 23_zpsbxzldgms
'74 El Camino "Project Badass" - Page 3 22_zpsqdyvcsam
'74 El Camino "Project Badass" - Page 3 20_zpsqgy8bjph
Liked a lot as front bumper came out, ideal fitment and gap along the whole car. Side's wings of the bumper end now directly where the fenders start. The same thing with the rear bumper, but in this position it still sticks out more than the front.
It's pleasure to think that may be this attempt of pressing in the bumpers is somewhere near the unsafe design of the car that may be existed on the factory as sketches Smile
Plus in the near future I will buy front spoiler from Randy's spoilers to complete the front part.
Now everything is waiting for sandblasting and colormatching to body.
I didn't go stock with chrome because several reasons.
First reason I didn't find any rechroming service, frankly speaking we don't have any, only if trying to get in touch with some Army plants but with unpredictable result.
Second reason is that the surface must be prepared and shaved to ideal to make real good chrome coating and I don't know who will do this for me.
Third reason is the price of this process.
Fourth reason is that chrome doesn't fit my car project style in my mind.
I don't know how everything will look like in reality in the end but I hope my car style taste won't fail.
Have a question to the forum. Anybody knows why they made so narrow height front bumper as you can see from photos and so wide height fender that stretches down and ends much lower that the bumper and bumper fillers? There are free mounting holes on the lower part of the fenders one on each right behind the wheel. May be some models haв any spoilers or plastic parts that join lower part of the fender and bumper?
builtnotbought
builtnotbought
Post by Joe73 on Tue Mar 01, 2016 2:57 pm
I think it was an attempt to allow the bumper to compress without damage to any panels. At low speeds of course hence the name 5 mph bumper.
Street Cred : 72
'74 El Camino "Project Badass" - Page 3 Empty Steering Column
Post by testpilot61 on Tue Mar 01, 2016 4:11 pm
The 73 to 77 chevelles were built from the factory with the columns out of alignment. Not sure why this was done but sure that some engineer had one of those "Brilliant" ideas.
On my 76 Malibu Classic I loosened the two bolts directly under the dash just enough to allow me to move my column from side to side until it suited what I wanted to do. Trial adjustments will help you determine what's right for you. Be sure to tighten bolts securely once you've settled on the right position.
Really like what your doing with bumpers. I've always disliked how the bumpers seemed to be an after thought, they didn't fit the rest of the cars design as well as all the additional weight of this design.
Keep up the Great work. I'm anxious to see the final results.
Jerry,
testpilot61
testpilot61
Post by tropdeprojet on Tue Mar 01, 2016 7:14 pm
I really like your project. It really see my project in yours!
tropdeprojet
tropdeprojet
Post by builtnotbought on Wed Mar 02, 2016 7:29 am
Joe73 wrote:I think it was an attempt to allow the bumper to compress without damage to any panels.  At low speeds of course hence the name 5 mph bumper.
Yes, plastic inserts F/R were made especially for what you told. But I was talking about this difference, circled red
'74 El Camino "Project Badass" - Page 3 20_zps10
And now when I saw tropdeprojet avatar again I understood that fenders were designed to fit Laguna nose Idea
testpilot61 wrote:The 73 to 77 chevelles were built from the factory with the columns out of alignment. Not sure why this was done but sure that some engineer had one of those "Brilliant"  ideas.
Jerry,
testpilot61
Thank you!
As I remember under dash bolts allow only forward/backward movement. I still didn't solve this problem, I will look.
I tried to fit single bucket seat and saw this strange disposition on the column.
I will look at it after installing oem bench, may be column was installed this way all it's life.
tropdeprojet wrote:I really like your project. It really see my project in yours!
Thank you Laughing
builtnotbought
builtnotbought
Post by bigredlaguna on Wed Mar 02, 2016 11:54 pm
I think the column offset in relation to the driver was an attempt by design to reduce or prevent impaling the driver with the steering shaft in a head on collision.
Street Cred : 53
Post by Hs1973 on Sat Mar 05, 2016 10:14 am
Or maybe someone tryed to steel it at some point and twisted the steering column in an attempt to break the steering lock. And you dident notice before you took it apart.
Point Being that these cars have had a rough life before we Got them. I know mine has been trough alot of owners and a lot of abuse in the 40 years prior to it landing in my garage. They was nothing more than an old Junker in the 80s and most did not care for them.
Street Cred : 12
Post by riddick75 on Wed Apr 13, 2016 10:31 pm
I like your project Thumbs up , wish I had the space you have to work in, and the pictures overhead looked awesome. keep up the good work, and as a side note, the welds on the frame were actually done by a machine, mine look just as crappy.
riddick75
riddick75
Street Cred : 6
Post by builtnotbought on Sat Apr 16, 2016 12:06 pm
bigredlaguna wrote:I think the column offset in relation to the driver was an attempt by design to reduce or prevent impaling the driver with the steering shaft in a head on collision.
Good idea, don't think about that.
Hs1973 wrote:Or maybe someone tryed to steel it at some point and twisted the steering column in an attempt to break the steering lock. And you dident notice before you took it apart.
I can't see any mechanical damage. I will make a scheme with interior photo in future to show what I meant, and of coarse I will check myself when bolt in bench to it's place.
riddick75 wrote:I like your project Thumbs up , wish I had the space you have to work in, and the pictures overhead looked awesome. keep up the good work, and as a side note, the welds on the frame were actually done by a machine, mine look just as crappy.
Thank you very much! Wow can't even imagine that they had welding robots half a century ago!
So as for the smugglers box and section behind the cabin. As I told above I always wanted to have air suspension, but usual hidden setup was too boring and besides that I had a enormous wish to try making smth extraordinary.
So where is the best place in Elcamino to place the airride management? Of coarse in the bed under floor behind the cabin! Less talk - more work!
Measured air tank in place where I designed in my head. Went out cool but smth was wrong. Why should I use one tank and one compressor if I have place for twice both?
'74 El Camino "Project Badass" - Page 3 18_zpshxd8y9cg
Glovebox hole in the rear cabin panel behind the driver was welded and partition that held the section cover was removed. Now two 20 gallon tanks with two compressors could fit my bed compartment. Ridetech ugly tank was sold and two Speciality suspension seamless tanks had taken place.
'74 El Camino "Project Badass" - Page 3 181_zps4r4k8twe
'74 El Camino "Project Badass" - Page 3 19_zpsrnyadsuy
'74 El Camino "Project Badass" - Page 3 27_zpsxdxwsogc
'74 El Camino "Project Badass" - Page 3 28_zpsrfrr5vhj
As for the smth extraordinary why should I go with boring flexible plastic lines and hide everything under cover if I can go hardlines and make a transparent cover to show everybody my system?
I never made any hardline before, no tools, no experience, knew nothing about fittings/tubing.
So the time went on and I was learning more and more about hardlines. I bought Ridgit bender, REms tube cutter, 12m of stainless 3/8 tubing, Hy-lok compression fittings and started designing the system. Luckely ordered tubing and fittings from Moscow after weeks of searching right spare parts.
'74 El Camino "Project Badass" - Page 3 20_zpsln3xls4b
'74 El Camino "Project Badass" - Page 3 25_zpsmf5ibam7
Besides that I bought 480C Viair's to feed the system, SMC check calves and elbows, AVS water traps, and 175psi safety valve to finish the system.
'74 El Camino "Project Badass" - Page 3 21_zpsbvkpkstp
I designed in Acad a holder for all the management and gave drawing to my metal man.
First variant of tubing was designed in Acad too. As the basis of design of coarse V8 letters were taken Very Happy
'74 El Camino "Project Badass" - Page 3 _zps9dvdhh0f
'74 El Camino "Project Badass" - Page 3 _zps5ysmg24m
Sometimes later first variant of holder was ready!
'74 El Camino "Project Badass" - Page 3 22_zpsu7k2xmuj
'74 El Camino "Project Badass" - Page 3 23_zps9nnctghv
'74 El Camino "Project Badass" - Page 3 24_zpsdoulekvw
We have a national proverb, it sounds like an - "eyes are afraid to look on but hands are doing" - with this thought I began to bend tubing. First attempt was half a luck but result impressed me.
'74 El Camino "Project Badass" - Page 3 30_zps9phwopou
'74 El Camino "Project Badass" - Page 3 29_zpskgmqf1il
'74 El Camino "Project Badass" - Page 3 31_zpslifrkntc
'74 El Camino "Project Badass" - Page 3 35_zpsjxaogqpp
'74 El Camino "Project Badass" - Page 3 36_zpsdlnkuago
First attempt of assembling the lines. Was restyled after final assembly.
'74 El Camino "Project Badass" - Page 3 32_zpslz8p5c6u
'74 El Camino "Project Badass" - Page 3 33_zpsyopmrm4u
'74 El Camino "Project Badass" - Page 3 34_zpsubbx0skd
'74 El Camino "Project Badass" - Page 3 37_zps4xfwp7a4
During the process I bought some brass tubing to made examples of bends and routes not to ruin expensive inch stainless steel tubing. It was hell =))
'74 El Camino "Project Badass" - Page 3 40_zpsmtpl804a
'74 El Camino "Project Badass" - Page 3 41_zpsv3qpff3y
'74 El Camino "Project Badass" - Page 3 39_zpsflrzqn83
It took me about seven months to made all tubing, restyle some tubing, made connections, bulkheads, management holder restyling several times and wiring, working in free time.
'74 El Camino "Project Badass" - Page 3 45_zpsl5dukb0l
'74 El Camino "Project Badass" - Page 3 44_zpst4dab6ww
'74 El Camino "Project Badass" - Page 3 43_zpsye0pxry2
'74 El Camino "Project Badass" - Page 3 42_zps44zxjihs
'74 El Camino "Project Badass" - Page 3 47_zps82jzuof4
'74 El Camino "Project Badass" - Page 3 48_zps9v4u3w1y
'74 El Camino "Project Badass" - Page 3 46_zpsrm8btpyi
It's not the final result.
'74 El Camino "Project Badass" - Page 3 49_zpstuqukmj7
'74 El Camino "Project Badass" - Page 3 %203_zpseo4btnfi
'74 El Camino "Project Badass" - Page 3 %201_zpswu16swvh
I'm planning to run Hornblasters train horn, so made an exit to it's valve but need to buy horns now.
Transparent cover now is under designing, so I need to clean all the tubing, sandblast and paint holder, put some carpet in the compartment and make everything work together!
The only question that worried me all this time was - water draining. As I know the bed is inclined to the cabin and all water from the bed flows to the rear wall of the cabin and underneath the cover of compartment.
My car had a lardge rusty hole in the rear wall of cabin as you saw in the beginning of the thread because of water containing in bed and it had selfmade drain holes in the floor of compartment, now they are welded.
Does anybody know how the factory water draining was designed and what can I do now to prevent water containing if I sealed close compartment cover?  Thank you
builtnotbought
builtnotbought
Post by alowerlevel on Sat Apr 16, 2016 11:47 pm
Holy s**t that turned out nice..... Makes me miss my old truck, only thing better than airing it out is dragging the hell outta it down the highway Twisted Evil
alowerlevel
alowerlevel
Street Cred : 6
Post by thatfnthing on Mon Apr 18, 2016 9:01 am
That is some excellent work! And the "V8" is a nice touch, too. Thumbs up
Street Cred : 58
Post by builtnotbought on Mon Apr 18, 2016 10:39 am
Thank you !!!
builtnotbought
builtnotbought
Post by pila on Mon Apr 18, 2016 11:31 pm
That's some outstanding work & craftsmanship you have done Very Happy Very impressive !!
Bill
Post by 74Malibu383 on Tue Apr 19, 2016 12:30 pm
Wow. Very nice. Looks great.
Post by builtnotbought on Tue Apr 19, 2016 3:04 pm
Thank you guys!
builtnotbought
builtnotbought
Post by Limey SE on Wed Apr 20, 2016 2:25 pm
pila wrote:That's some outstanding work & craftsmanship you have done Very Happy  Very impressive !!
Bill
x2
'74 El Camino "Project Badass" - Page 3 12527912
Street Cred : 91
Post by DaveFury on Wed Apr 20, 2016 2:53 pm
Bill
x2
X3
Dave W.
DaveFury
DaveFury
Post by builtnotbought on Sat Apr 23, 2016 6:22 pm
Thank you, I'm very pleased )
Let me please repeat my question about bed from the post above:
"The only question that worried me all this time was - water draining. As I know the bed is inclined to the cabin and all water from the bed flows to the rear wall of the cabin and underneath the cover of compartment.
Does anybody know how the factory water draining was designed and what can I do now to prevent water containing if I sealed close compartment cover? Thank you"
Have a little more photos.
Fabricated a frame for tci trans cooler and derale power steering cooler. Need to connect trans cooler to lines.
'74 El Camino "Project Badass" - Page 3 Img_7011
'74 El Camino "Project Badass" - Page 3 Img_7012
Tried to fit some modern seat from passat. Lookes very cool without headrest. While fitting I noticed that steering column is turned to the drivers door and it can't be moved in other position - I checked. So I don't know how people drive in bucket seats.
'74 El Camino "Project Badass" - Page 3 Img_7113
'74 El Camino "Project Badass" - Page 3 Img_7112
'74 El Camino "Project Badass" - Page 3 Img_7110
'74 El Camino "Project Badass" - Page 3 Img_7111
I tried to draw an angle that's steering column has. With bucket seat it's very noticible. With bench - far less, because it's flat and you can seat more closer to door.
'74 El Camino "Project Badass" - Page 3 Img_8224
'74 El Camino "Project Badass" - Page 3 Img_8223
Re-welded my right "bolt-on" Hooker header plus change the direction of lower 3" piece of pipe.
'74 El Camino "Project Badass" - Page 3 Img_7410
'74 El Camino "Project Badass" - Page 3 Img_7411
Cutted an example of my bed cover to see where will be paint/transparency border.
'74 El Camino "Project Badass" - Page 3 Img_7512
'74 El Camino "Project Badass" - Page 3 Img_7511
Bought new glove box cap and oem battery tray from one really nice guy from Canada.
'74 El Camino "Project Badass" - Page 3 Img_7611
'74 El Camino "Project Badass" - Page 3 Img_7610
Bought front side frame reinforcement from monte carlo but they didn't fit at all, headers and even didn't fit frame mount holes. Tried to fit several times. Suspect
'74 El Camino "Project Badass" - Page 3 Img_7013
Took back full interior from trim shop. Everything is re-trimmed in black leather/alcantara. Most of the metal interior elements are saved from painting and are sanded by hand to look like brushed aluminium. It was a surprise for me that most of the pieces are from stainless steel Thumbs up
Photos will be after everything will be mounted in place.
Besides that trim shop made new 6 pieces carpet including rear wall carpet + new floor mats.
'74 El Camino "Project Badass" - Page 3 Img_7615
'74 El Camino "Project Badass" - Page 3 Img_7614
And a little piece of carpet in the bed. Didn't fit well, but this waves won't be seen under painted part of the cover. Don't want to drill bed to screw carpet.
'74 El Camino "Project Badass" - Page 3 Img_7612
Drill some fun staff, Ridetech logo in the caps.
'74 El Camino "Project Badass" - Page 3 Img_7613
'74 El Camino "Project Badass" - Page 3 Img_7810
'74 El Camino "Project Badass" - Page 3 Img_7811
Decided to make custom cluster overlay. Made a stencil from paper and draw it in Acad. Now I plan to trim it from a piece of stainless steel and sand it to match all brushed pieces.
'74 El Camino "Project Badass" - Page 3 Img_7710
'74 El Camino "Project Badass" - Page 3 Img_7711
'74 El Camino "Project Badass" - Page 3 Img_7712
Drilled holes for Sunpro gauges, fitted like they are from factory. Need only to refinish the glass.
'74 El Camino "Project Badass" - Page 3 Img_7812
'74 El Camino "Project Badass" - Page 3 Img_7813
And the near final result of hardlines without cover.
'74 El Camino "Project Badass" - Page 3 Oaia_411
builtnotbought
builtnotbought
Post by builtnotbought on Mon Apr 25, 2016 2:37 pm
Forgot to mention that I colormatched booster new and used a stand from stock booster to align push rod into the hole in the firewall (brackets from kit are no use), wiper bottle and repainted trimmed bumper filler.
'74 El Camino "Project Badass" - Page 3 Img_8112
Installed booster+ master cylinder
'74 El Camino "Project Badass" - Page 3 Img_8229
And tried to put on door water shields. PLastic shields are ok with 3m tape on door, but insulation...any ideas of the best way to glue it?
'74 El Camino "Project Badass" - Page 3 Img_8228
'74 El Camino "Project Badass" - Page 3 Img_8227
Any thoughts about water drainage in bed of elco?
Appreciate any help
Thank you!
builtnotbought
builtnotbought
Post by bigredlaguna on Mon Apr 25, 2016 3:17 pm
How to remove water from the bed of an El Camino: 1) lower tailgate 2) Accelerate quickly. Cool
I've never messed around with an El Camino, but I do not think they had any drainage capacity near the cab. You may want to make your own drains. Otherwise, just make sure the cover is watertight.
Street Cred : 53
