Tilt Column Fitment
Tilt Column Fitment Empty Tilt Column Fitment
Post by SSTOOLMAN on Fri Dec 25, 2015 12:57 pm
I have been looking for a tilt column for some time and found one out of a 76 442, I thought I read some where that columns for my 73 SS are slightly different but wasn't sure. Can anybody please help? I don't want to let this one get away.
Merry Christmas Everyone!
SSTOOLMAN
SSTOOLMAN
Tilt Column Fitment Empty Re: Tilt Column Fitment
Post by Limey SE on Fri Dec 25, 2015 1:10 pm
you have to use your Lower steering shaft (where it bolts to the rag joint) And take the Plugs of your Column there Different from 73 to 76 other than that GRAB THAT BOOGER and switch
Tilt Column Fitment 12527912
Street Cred : 92
Post by SSTOOLMAN on Fri Dec 25, 2015 6:32 pm
Limey SE wrote:you have to use your Lower steering shaft (where it bolts to the rag joint) And take the Plugs of your Column there Different from 73 to 76 other than that GRAB THAT BOOGER and switch
What do you mean "plugs?"
SSTOOLMAN
SSTOOLMAN
Post by Limey SE on Fri Dec 25, 2015 6:34 pm
the Ignition switch and every thing that's bolted to your current column in your 73 ( including the dash brackets for the bolts, just have to use your 73 Bracket) has to be switched over to the 76 Column
Street Cred : 92
Post by SSTOOLMAN on Fri Dec 25, 2015 9:04 pm
OK thanks Anthony,
SSTOOLMAN
SSTOOLMAN
Post by Limey SE on Fri Dec 25, 2015 9:28 pm
where they at ??
Street Cred : 92
Post by SSTOOLMAN on Fri Dec 25, 2015 11:21 pm
Cleveland Ohio
SSTOOLMAN
SSTOOLMAN
Post by Limey SE on Fri Dec 25, 2015 11:33 pm
I have a few friends in that that area if you want me to have them grab and ship ?? They are members here as well
Street Cred : 92
Post by SSTOOLMAN on Sat Dec 26, 2015 12:00 am
PM sent
SSTOOLMAN
SSTOOLMAN
