quarter panels sedan vs coupe
2 posters
Yes I'm a sedan guy in a coupe world. So the question concerns the quarter panels for a 76. I understand the exact difference in the front side of the quarter panel between the two. The sedan has a skinny looped curve around the front side of the wheel well while the coupe has a noticeably wider and straighter section there. But from the wheel well opening to the tail section are the coupe and sedan quarters exactly the same? Thanks for any info.
76Chevelle2Tone- G3GM Member
Re: quarter panels sedan vs coupe
I think I remember someone here on the forum discussing this a few years back. I think the wheel well molding is the same for both the sedan and coupe? Anyone have a reference book with part numbers to verify? If they are the same then I would think the rest of the quarter panel would be very similar if not exact.
- Street Cred : 33
probably the same but ...
Thanks for your reply. I think they are the same too after the door side difference but the car makers often do weird little things so that's why I am asking. The 73 quarters are just a little bit different past the wheel well compared to 74-77 apparently. I was just hoping someone had used a sedan quarter on their coupe and could verify everything was exactly the same past the wheel well.
» Rear Quarter Half-Panels??
» wanted: 74, 75 malibu classic interior quarter window sail panels
