rattle can 73 ss stripe paint
G3GM :: G3 Tech :: Body
rattle can 73 ss stripe paint Empty rattle can 73 ss stripe paint
Post by clanceman427 on Tue Feb 09, 2016 7:58 am
Anybody know a decent rattle can silver paint to match the 1973 Chevelles SS lower body stripe, the light silver version? Not looking to have paint mixed for a gun, instead just a store bought that I can do some quick touch ups? Again just needs to be close not perfect.
rattle can 73 ss stripe paint Empty Re: rattle can 73 ss stripe paint
Post by Limey SE on Tue Feb 09, 2016 8:25 am
Orileys can custom mix a color for Spray cans for you
Street Cred : 92
Post by Joe73 on Tue Feb 09, 2016 8:37 am
Duplicolor has the closest. I can get thepartnumber when i get home.
Street Cred : 73
Post by clanceman427 on Tue Feb 09, 2016 8:50 am
Thanks!
Post by clanceman427 on Tue Feb 09, 2016 8:51 am
Limey SE wrote:Orileys can custom mix a color for Spray cans for you
Darn. We have most auto parts chains around here, but not Oriellys.
Post by Joe73 on Tue Feb 09, 2016 9:24 am
Alot of auto body supplies will mix it for u but it will be 2 stage paint. So if u have left over it will harden in the can. Duplicolor will be an enamel and have a long shelf life with leftovers.
Street Cred : 73
Post by Hawk03 on Tue Feb 09, 2016 9:30 am
You're not missing much, the same people work there as all the other department stores. Knowledge? Skill? Not so much.
Try paintscratch.com, they might have something close or mix it up what you need.
Street Cred : 13
Post by Joe73 on Tue Feb 09, 2016 6:27 pm
Ok, duplicolor HWP101 is real good. I've also heard good things about krylon 1403 dull aluminum but I havent seen the krylon in person.
Both should get a coat of clear on top of the silver.
This info is going from info I've saved from years ago concerning stripe colors and rally wheel paint .
I'd dust it on in a small area, then second coat a little larger area and if your going with a third then a slightly larger area. Just for a "blend" effect. Remember to clean the area real good with wax and grease remover or in a pinch rubbing alcohol. Either way, keep the area wet for at least a couple minutes to let it work. I use a spray bottle of wax and grease remover. I keep mineral base and water based w/g around for projects.
Good luck with it.
Street Cred : 73
Post by clanceman427 on Tue Feb 09, 2016 7:57 pm
Thank you very much Joe!
Post by clanceman427 on Mon Jun 13, 2016 9:53 pm
Joe thanks again, I touched up some of my stripes with that wheel paint you recommended and it is a real good match!
Post by Joe73 on Tue Jun 14, 2016 6:16 am
your very welcome.
Street Cred : 73
