Chevelle SE 1/9/2020 Interior Update
Page 7 of 9 Previous  1, 2, 3, 4, 5, 6, 7, 8, 9  Next
Chevelle SE  1/9/2020 Interior Update  - Page 7 Empty Re: Chevelle SE 1/9/2020 Interior Update
Post by Limey SE on Wed May 30, 2018 9:46 am
2" at most of it ..... I had to fab about a 2.5 x 1.5 section to go where welder cut too much out on pass side toe board towards trans tunnel upward sweep...... I have to do underneath on the bottom side seam sealer also the spots are from the sheet metal screws to hold the panel Bond Secure cuz you have to have something to hold it because it needs a very strong adhesion
Street Cred : 92
Post by impalamonte on Wed May 30, 2018 1:03 pm
And.....the quarter panels are "glued" onto the new Camaro. Corvettes have been "bonded" together in some area for the last couple of years too !
Street Cred : 12
Post by buggy5872 on Thu May 31, 2018 7:59 am
Looks good. It will be just as strong as welding. Panel adhesives are really strong and it is sealed. When I need to patch a floor and cant take the interior out, I glue them.
buggy5872
buggy5872
Post by Limey SE on Fri Jun 01, 2018 10:36 pm
5am wake up call friday june 2nd ...........CARPET in all I have left is to bolt seats down, assemble shifter and console and enjoy at Dakota Illinois Car Show Swap meet Chevelle SE  1/9/2020 Interior Update  - Page 7 20180610
Chevelle SE  1/9/2020 Interior Update  - Page 7 20180611
Chevelle SE  1/9/2020 Interior Update  - Page 7 20180613
Chevelle SE  1/9/2020 Interior Update  - Page 7 20180612
Street Cred : 92
Post by Limey SE on Sat Jun 02, 2018 8:10 pm
Well Got er done and made it to Car Show Was very Pleased to hear all the positive things about Car today .... Old timer with a an Original 68 Malibu parked next to me and he Chewed my ear off He was a Very Nice retired older Gent He was original owner to the 1968.... Had a great Time Chevelle SE  1/9/2020 Interior Update  - Page 7 34105110
Chevelle SE  1/9/2020 Interior Update  - Page 7 34133010
Chevelle SE  1/9/2020 Interior Update  - Page 7 34133910
Chevelle SE  1/9/2020 Interior Update  - Page 7 34140910
Chevelle SE  1/9/2020 Interior Update  - Page 7 34175210
Chevelle SE  1/9/2020 Interior Update  - Page 7 34348710
Chevelle SE  1/9/2020 Interior Update  - Page 7 34368810
Chevelle SE  1/9/2020 Interior Update  - Page 7 34394510
Street Cred : 92
Post by Limey SE on Sat Jun 23, 2018 6:22 pm
GOT SOME ORGINAL COLOR BACK ON OL GIRL  yayyyyy  SE looks so different with the black hood gone BUT In a good way   Chevelle SE  1/9/2020 Interior Update  - Page 7 34962410
Chevelle SE  1/9/2020 Interior Update  - Page 7 36087310
Street Cred : 92
Post by thatfnthing on Sun Jun 24, 2018 11:05 am
I like it!
Post by Limey SE on Sun Jun 24, 2018 3:54 pm
Not to bad of a result from spray cans it's enamel paint so no clear needed unless I want it so my paint neighbor says Chevelle SE  1/9/2020 Interior Update  - Page 7 20180611
Street Cred : 92
Post by 77camino on Sun Jun 24, 2018 5:40 pm
Is your plan to rattle can the whole car until you can have it painted. Are you going to mask the stripes off and paint around them. Looks good!
Post by Limey SE on Sun Jun 24, 2018 5:50 pm
Yeah that's my plan I just want to get it all one color till I can get it professionally done and get get rid of the rest before I have any more problems especially with brand new quarters in the back and yes I plan on masking the stripes off till I can have them made
Street Cred : 92
Post by Limey SE on Mon Sep 24, 2018 6:15 am
Have a 1993ish 454 TBI motor for the SE now will be switching it from TBI to carb over the winter and making it look good or least better than it does.... have 781 heads and a Holley street dominater intake my quickfuel carb and longtube headers and with right cam choice should be nice
Chevelle SE  1/9/2020 Interior Update  - Page 7 20180912
Chevelle SE  1/9/2020 Interior Update  - Page 7 20180913
Street Cred : 92
Post by bracketchev1221 on Mon Sep 24, 2018 8:37 am
That engine needs an electric fuel pump right?
Post by Limey SE on Mon Sep 24, 2018 8:07 pm
Yes sir it does it also appears night be a roller motor will know this weekend when removing intake Chevelle SE  1/9/2020 Interior Update  - Page 7 20180914
Street Cred : 92
Post by bracketchev1221 on Tue Sep 25, 2018 8:31 am
Based on it being a 93, I would guess its a flat tappet motor. What cylinder head casting is on it now? The 781 is an open chamber head so you will want to see what your final compression numbers would be.
Post by Limey SE on Tue Sep 25, 2018 10:06 am
According to the casting number on block it indicates a roller motor BUT could be wrong IT IS FROM A 2500 pickup
Chevelle SE  1/9/2020 Interior Update  - Page 7 20180915
Chevelle SE  1/9/2020 Interior Update  - Page 7 20180916
Street Cred : 92
Post by bracketchev1221 on Tue Sep 25, 2018 5:57 pm
Make sure you look into the head gaskets. You will need to make sure it is a conversion gasket to adapt a Mark IV head onto a Gen 5 block. The water passages are different.
Post by Limey SE on Sun Sep 30, 2018 9:51 pm
Finally able to get the posi 3.08 rear ready cor the transplant all I have to don't I it is new brake lines Thank You Joe73 the cover is perfect for it, also have the boxed control arms that a member here makes ready and waiting with the impala SS sway bar Chevelle SE  1/9/2020 Interior Update  - Page 7 Receiv10
Chevelle SE  1/9/2020 Interior Update  - Page 7 20180918
Chevelle SE  1/9/2020 Interior Update  - Page 7 20180917
Street Cred : 92
Post by dhw3971 on Tue Oct 02, 2018 1:54 pm
What improvement is gained by boxing the control arms?
dhw3971
dhw3971
Post by bracketchev1221 on Tue Oct 02, 2018 2:09 pm
Cuts down on arm flex. Better for cornering and higher HP.
Post by Limey SE on Sun Oct 07, 2018 6:20 pm
bracketchev1221 wrote:Make sure you look into the head gaskets.  You will need to make sure it is a conversion gasket to adapt a Mark IV head onto a Gen 5 block.  The water passages are different.
Thanks for the Tip ray yes I will need the different gasket ...... Talked to the Place today and have to get the one with less Water passages
Top picture is One I need .....Bottom pic is one that was for 90 and down 454
Chevelle SE  1/9/2020 Interior Update  - Page 7 555-210059
Chevelle SE  1/9/2020 Interior Update  - Page 7 375-1017-1
Street Cred : 92
Post by Limey SE on Thu Oct 11, 2018 10:14 pm
Ok Guys / Gals I know I need an external fuel pump to run the 454 so any suggestions for on the less expensive side of life
??? And flexplate best place to buy cheaply
Street Cred : 92
Post by Limey SE on Thu Oct 18, 2018 1:17 pm
Yay test fit worked good .... Thought for a minute I had a tall deck 454 but forgot I needed the conversion I take gasket so I can run gen IV heads on a Gen V block lol Chevelle SE  1/9/2020 Interior Update  - Page 7 Img_2012
Street Cred : 92
Post by thatfnthing on Thu Oct 18, 2018 3:16 pm
Nice!
Post by bracketchev1221 on Fri Oct 19, 2018 4:40 am
Limey SE wrote:Yay test fit worked good .... Thought for a minute I had a tall deck 454 but forgot I needed the conversion I take gasket so I can run gen IV heads on a Gen V block lol Chevelle SE  1/9/2020 Interior Update  - Page 7 Img_2012
No such thing as a factory tall deck 454 so you're safe there. They only came in 366 or 427 hd trucks.
Post by Limey SE on Thu Oct 25, 2018 6:00 am
Well after much disappointment with the 454 I sent it on its merry way to a core buyer and used that cash to Get a 396 for the SE instead so far it's a 1000% improvement....
there were so much rust pits in it he would have had to sleeve 3 of 8 cylinders
Chevelle SE  1/9/2020 Interior Update  - Page 7 20181011
Chevelle SE  1/9/2020 Interior Update  - Page 7 20181010
Street Cred : 92
