Chevelle SE update 9/17/2020 sanding sanding sanding Argggg
Page 10 of 11 Previous  1, 2, 3 ... , 9, 10, 11  Next
Chevelle SE update 9/17/2020  sanding sanding sanding Argggg - Page 10 Empty Re: Chevelle SE update 9/17/2020 sanding sanding sanding Argggg
Post by Limey SE on Sat Apr 04, 2020 12:34 pm
77mali wrote:Looking good Thumbs up
Thanks Mali
Chevelle SE update 9/17/2020  sanding sanding sanding Argggg - Page 10 91624710
Street Cred : 95
Post by bracketchev1221 on Mon Apr 06, 2020 6:04 pm
When are we going to see this big block going together?
Post by 77camino on Mon Apr 06, 2020 6:07 pm
Is the big block going in car #1 or car #2?
Street Cred : 6
Post by Limey SE on Mon Apr 06, 2020 7:33 pm
bracketchev1221 wrote:When are we going to see this big block going together?
77camino wrote:Is the big block going in car #1 or car #2?
Well Hopefully soon, I have been fighting some health issues since last September lost job because of it (gastrointentestinal issues) I finally get that squared away with Meds rest of life, Then was looking like I could go back to work when released from Dr care, and wouldn't ya know Life happened back to back. Was taking garbage to curb and a bag fell out of wagon I bent down to pick it up, stood up aand felt pop pop in my Left knee was paralyzed where i stood till she got back from taking kids to school.
Well 10 minutes later im in ER having my Knee xrayed yup POP POP = two fractures I am currently 5 weeks now on Crutches with another 6 to 7 weeks to go before I can walk with out sticks yet SO its all on Hold so I can learn to walk again without crippling pain .......
454 will be going in the Second one, I think now. I was gonna put it in the original One BUT Started thinking that would be the better one for my Daughters Graduation Still up in the air though, I have to pull the 305 out and at the least freshen the gaskets it has sat for 3.5 years before I got it and with all the crap my body has put me thru in the last 20 months between almost having my Leg amputated from 2 bouts of celluitis and then intestentinal issues then the dang Fractured Knee, So all together total time from Previous owner and Myself its sat for close to 6 years....
About the Only gasket on Motor and trans that hasnt started to leak are the head gaskets LOL
I AM I WILL GET THIS DONE
Street Cred : 95
Post by Limey SE on Thu Apr 09, 2020 10:57 pm
SNEAK PEEK for Plans in very near future adding a 1980 Camaro Z/28 Functional Cowl Scoop
Chevelle SE update 9/17/2020  sanding sanding sanding Argggg - Page 10 92691010
Street Cred : 95
Post by thatfnthing on Fri Apr 10, 2020 8:39 am
That'll be interesting, but it looks like a buttload of work -- I'll be interested to see what mods you have to make.
Post by Limey SE on Fri Apr 10, 2020 10:38 am
thatfnthing wrote:That'll be interesting, but it looks like a buttload of work -- I'll be interested to see what mods you have to make.
I have everything to make it Functional THE BIGGEST part will be smoothing the Hood line where it doesn't get covered by the scoop also have to switch gas pedal assemblies for the actuator for the flappers is on the gas pedal
Chevelle SE update 9/17/2020  sanding sanding sanding Argggg - Page 10 87678910
Chevelle SE update 9/17/2020  sanding sanding sanding Argggg - Page 10 87902810
Chevelle SE update 9/17/2020  sanding sanding sanding Argggg - Page 10 88180710
Chevelle SE update 9/17/2020  sanding sanding sanding Argggg - Page 10 85087810
Chevelle SE update 9/17/2020  sanding sanding sanding Argggg - Page 10 86233010
Street Cred : 95
Post by thatfnthing on Fri Apr 10, 2020 11:14 am
Okay, but aren't you looking also at closing up the pre-existing vent slots in the back of the hood? And if it's going to be functional, doesn't that require messing around with the hood's underside bracing so the air comes in the right place? That seems like a lot of work to me -- not necessarily a bad thing, just more stuff on the to-do list.
And THEN you get to do all the actual bodywork. Smile
Post by Limey SE on Fri Apr 10, 2020 11:28 am
I dont believe the hoods vent holes have to be covered this is Dcotor Larrys Car it wont have the side heat extractor vents though
Chevelle SE update 9/17/2020  sanding sanding sanding Argggg - Page 10 87522910
Street Cred : 95
Post by thatfnthing on Fri Apr 10, 2020 11:49 am
Well, okay, that certainly avoids the vent slot issue (and looks good), but then if you're not right up against the windshield, don't you lose the high-pressure air effect you're after?
Post by Limey SE on Fri Apr 10, 2020 12:15 pm
Will lose some i do believe but where it stops is about where all the Cowl hood scoops stop is about the same spot
Street Cred : 95
Post by fasrnur on Fri Apr 10, 2020 3:16 pm
That looks like a lot of fabricating to me. Not sure what the benefits of it would be other than the cool factor. When Chevy came out with the cowl induction hood, they spent loads of money to figure out that the area at the bottom of the windshield and the end of the hood was dead air. By putting the scoop at the end of the hood and close to the windshield the air would then be forced forward into the scoop. If you don't mount a cowl scoop in the same manner, you're actually not taking advantage of that effect.
Just my two cents sir.
Post by Limey SE on Fri Apr 10, 2020 4:44 pm
The Z/28 scoop does stop before the hood vents also and Looking at the bottom of hood that is what will determine where the scoop will live I want it as Close to the windshield as possible ........ And I can do this work while still on crutches to a point so why not get this project out of way while healing then can switch to the finish the 454 completion once fully off crutches.
Street Cred : 95
Post by fasrnur on Fri Apr 10, 2020 5:28 pm
You're right Limey. I forgot about the vent just in front of the windshield. Are you putting the 454 in the first or second SE?
Post by Limey SE on Fri Apr 10, 2020 6:29 pm
I haven't decided yet either way it just a bolt in thing just like the scoop so its very reversable
Street Cred : 95
Post by Limey SE on Wed May 20, 2020 5:59 pm
So it starts I have alot of sanding to do LOL But I'm finally able to start it somewhat gonna do rear quarters first as the primer sealer from previous owner is showing rust, I did the hood this way 2 years ago so its stood up over all I will do the rear quarters first then get enough paint to to do rest of car premixed and Apply with a Gun
I CANT WAIT TO SEE THIS Car all ONE color Finally !!!!!
Chevelle SE update 9/17/2020  sanding sanding sanding Argggg - Page 10 98341911
Chevelle SE update 9/17/2020  sanding sanding sanding Argggg - Page 10 98350011
Chevelle SE update 9/17/2020  sanding sanding sanding Argggg - Page 10 36087312
Street Cred : 95
Post by g3chevy on Wed May 20, 2020 10:29 pm
You'll be happier than a pig in mud when you get it done. Post pics of the process to keep the rest of us motivated.
g3chevy
g3chevy
Post by Limey SE on Wed May 20, 2020 11:11 pm
ALready happy I can start on it finally after all this injury crap
Street Cred : 95
Post by Mitchell Murphy on Fri May 22, 2020 8:03 am
Some things in life are well worth the wait! That will be really neat, love hood scoops that are functional. All should be. Will look forward to seeing this, what a conversation piece to add to the already great story of the end of the Chevellle name plate. We the G3 boys share in your excitement. Mitch
Mitchell Murphy
Street Cred : 6
Post by Limey SE on Fri May 22, 2020 9:43 pm
First Picture is how it started
Well as Promised I started this Morning on Body work (I know I know i said Yesterday but was rainy) Any who Bodywork 2020 has finally started on the SE It could have turned out better I think BUT I was doing 90% sitting down in a chair due to my Double Knee fracture Enjoy the Pics and dont be too brutal It was done Outside LOL
Chevelle SE update 9/17/2020  sanding sanding sanding Argggg - Page 10 32468410
Chevelle SE update 9/17/2020  sanding sanding sanding Argggg - Page 10 99275910
Chevelle SE update 9/17/2020  sanding sanding sanding Argggg - Page 10 99294010
Chevelle SE update 9/17/2020  sanding sanding sanding Argggg - Page 10 99296910
Chevelle SE update 9/17/2020  sanding sanding sanding Argggg - Page 10 98319510
Chevelle SE update 9/17/2020  sanding sanding sanding Argggg - Page 10 98480910
Chevelle SE update 9/17/2020  sanding sanding sanding Argggg - Page 10 99423810
Chevelle SE update 9/17/2020  sanding sanding sanding Argggg - Page 10 99294011
Chevelle SE update 9/17/2020  sanding sanding sanding Argggg - Page 10 99425610
Chevelle SE update 9/17/2020  sanding sanding sanding Argggg - Page 10 10057710
Chevelle SE update 9/17/2020  sanding sanding sanding Argggg - Page 10 99367210
Chevelle SE update 9/17/2020  sanding sanding sanding Argggg - Page 10 99149710
Street Cred : 95
Post by MaliCrusier / Mitch on Sat May 23, 2020 10:43 am
Awesome work Limey!
MaliCrusier / Mitch
MaliCrusier / Mitch
Post by Limey SE on Sat May 23, 2020 2:31 pm
Better look after drying off all night I have one little 1.5" long run to fix but will address that before paint onto the the other side in a few days
afro Thumbs up afro
Chevelle SE update 9/17/2020  sanding sanding sanding Argggg - Page 10 100590564_10222662449570316_3751482288982982656_o.jpg?_nc_cat=105&_nc_sid=ca434c&_nc_oc=AQnICSJ0BN74Hl_JqIHOFKjcLKscreTjQQaFC8HfeWc_hJP5CSgB8p1OKcXwkB9F6Jo&_nc_ht=scontent-ort2-2
Street Cred : 95
Post by g3chevy on Sat May 23, 2020 2:37 pm
How do you eat an elephant? One bite at a time. Looking good!
g3chevy
g3chevy
Post by Limey SE on Sat May 23, 2020 2:49 pm
g3chevy wrote:How do you eat an elephant? One bite at a time. Looking good!
Mighty Tasty Elephant i would say LOL
Street Cred : 95
Post by g3chevy on Sat May 23, 2020 3:16 pm
Amen!
g3chevy
g3chevy
