1977 Chevelle SE Major setback BUT end result will be worth it
+34
bucket
Iggy
MaliCrusier / Mitch
Mitchell Murphy
1975 S3
Zaptiah
dhw3971
buggy5872
marx3
zot
DaveFury
SSTOOLMAN
tropdeprojet
74 beast
38 posters
Page 2 of 21
Page 2 of 21 • 1, 2, 3 ... 11 ... 21
Re: 1977 Chevelle SE Major setback BUT end result will be worth it
jerry46765 wrote:Looks pretty good.
How is this one optioned in comparison to the black one?
Two barrel - 350?
Get driving it so you and the family can enjoy it.
Thanks -
Jerry
Only thing I have to do is the floor pans ( he passed before he got to them) and No not a 350 its a 305 even title states a 305 in vin it runs so good though I am NOT going to mess with it even has dual exhaust and sounds dam good for a 46605 Mile car Has A/C, cruise, tilt, standard windows and locks
Nice score SE. Good to see it's home now.
Dave W.
Dave W.
DaveFury- G3GM Member
Thank you for the offer, but im from Copenhagen Denmark. And the freight plus taxes would kill me. I was close to purchase a complete set of NOS mouldings all 4 fenderlip mouldings and the wide moulding in the bottom of the body. It was a member in here, he was asking 1500 dollars for all brand new. But freight and taxes to my door would be close to 2000 dollars plus the 1500, thats a bit steap.
But luck would have that a buddy has 2 complete set i can steal for cheap.
It looks like a Nice easy projekt so i hope you have that Road rocket painted and ready soon. I enjoy watching other guys build storys.
Hs1973- G3GM Enthusiast
Well been raining for three four days off and on I couldn't do anything inside the car because the inside of the car would get soaked so I pulled the tail lights off and finish them got that out of the way
Well got the Mini Quarry from Under the hood Kinda cleaned up, Then cleaned the Red 4 spoke steering wheel for when I switch the bad tilt out for the one that was included with the car.
Progress is Progress right ?
I'd take a look at these. Good reads on tilt columns.
http://www.crankshaftcoalition.com/w...ck_Rebuild.pdf
http://ls1tech.com/forums/general-ma...oval-pics.html
You can fix the one that came with the car.
- Street Cred : 80
Joe73 wrote:I'd take a look at these. Good reads on tilt columns.
http://www.crankshaftcoalition.com/w...ck_Rebuild.pdf<== Not Found
The requested URL /w...ck_Rebuild.pdf was not found on this server.
http://ls1tech.com/forums/general-ma...oval-pics.html <<==== The requested page was not found.
Click here to return to the homepage or try searching for the content you're looking for.
Google this " jazzman steering column " If you cant find the pdf. PM me your email and I'll send it to you.
- Street Cred : 80
found it Joe Thanks
Progress IS good ... looks right at home!
pigValve.paceMaker.cowValve | 79 CC to 1995 Mercury Grand Marquis?!
"Never compromise what's right" __ Aaron Tippin __ 'You've Got To Stand For Something (Or You'll Fall For Anything)'
Thanks Cort means alot Brother..........
Well the high wind gust's have limited my Shed assembly progress and with the Looming Thunderstorm's I couldn't start on interior either. So I decided to start the Transformation of the Ugliest GM engine color ever used GM coorperate Blue, Thank You John AKA Dynchel for the cover's.
Ok was messing around today between the Ice, rain and Mother Nature B.S. Verified true Western 8.5" wide Wheel's and also Have the 11" brakes in rear already HMMM.... Has dual exhaust also, Don't know about dual exhaust trans member or not yet Have to replace windshield soon its leaking when it rains, It is bad enough to get the Carpet wet every time, But I have floor pans already that are needed and everything else needed for floor's
Did you definitely find the place where the windshield is leaking?? If not, I'd pull the cowl screen and check the bottom of the cowl. If dirts been laying in there the bottom could be rotted and water drops right onto the tranny hump and rolls down to the floor. Just a thought.
- Street Cred : 80
yup coming in right hand side Upper corner of it I can see where its coming in when it raining, Cowl screen is Clear no leave's no dirt. Which is Surprising for how much dirt an gravel dust is inside of car I doubt this car has ever been Vacuumed at all ever
I'd still pop the cowl screen out. With all the dust your talking about it could be caked up in the cowl. Dirt and dust goes easily through the screen.
- Street Cred : 80
Mine was rotted out in the passenger side. There is a heater duct that goes into the Cowl area. And it was leaking Real bad and was rustet round that plastic duct. It was a pain to fix, and i means you need to remove the heater box and surroundings. That means the complete istrument out with Glove box etc. Also the windshield and the top of the Cowl needs to be drilled out and rewelded back after repairs. Also the hood and the right fender needs to be removed. But now, no more water on the floors. Also i did not use caulk but modern glue to put the Windows back in. It is not seen when the moldings are put back. But it holds up alot better. Also the Windows are 100% leak free.
In the ends of the Cowl are 2 large holes where water and dirt runs out. One mine there was a rubber flab that i dont know why is there, because it prohibits dirt and leaves from running out with the water, and so i traps it and keep tha area moist. So i removed them and sprayede the whole Cowl with por 15 and 2 layers of paint and then rustolium.
It is the worst area that you cant even see or clean Real good. I have also glued some clear film on the back of the Cowl screen. And i have closed all small holes with rubber plus. To keep water out when i wash it.
I agree iwth hs1973. I've quite a few cowls rotted out. If I remember correctly, my buddy welded in new metal to the bottom of the cowl by removing the dash board. Then you can get to the bottom of the cowl for repairs. If I'm remembering right.
My buddy also thought it was a windshield leak.
- Street Cred : 80
I have seen the Leak though, Sorry for The confusion but have seen where its Leaking not just word of mouth from old owner LOL
New rims & tires look great. The turbine wheels were part of the SE package? Surprised to see 8.5 inch. Big for 77.
73ss- G3GM Enthusiast
Thanks Will prob Only run when I go to Track with Buddies for fun Sure aint gonna break 17 seconds with a 305 2v LMAO
And yea all the SE's came with them 8.5" wide and 60 series tires
If it is only the windshield leaking you are lucky. It is usually because the old caulk is dryed out and cant adhere to the glass and the window frame. Its an easy fix though. As long as you dont Fall for the urge to aply silikone based sealer around the glass, to try and stop the leak. It wont stop it and the you have alot of trouble with paint later. Also the silikone is hard to remove completely, and nothing sticks to it.
I always remove and clean the frame and glass Real good. Then i paint the edge of the glass with a Black glass primer. When its dry, i glue the glass back in with a modern glass glue. It always works and is leak free. It also looks Nice.
Im sure you already know all of this, im just a blappermouth. Lol anyways im happy you where just making aprils fool. And im looking forward to see it done.
Regards henrik
Regards henrik
Hs1973 wrote: I always remove and clean the frame and glass Real good. Then i paint the edge of the glass with a Black glass primer. When its dry, i glue the glass back in with a modern glass glue. It always works and is leak free. It also looks Nice.
Regards henrik
The Glass is also Cracked all the way across so When I replace the glass I will clean and repair any damage I find in the channel in that Time, And thanks for the Tip painting the side I just learned of this trick a few years ago while watching Blue Collar Buick build on Horsepower TV also Learned how to Repair the Dash with this Show also, But any shared Knowledge is always good Henrick Thank you Anthony
You are welcome. I have been into old cars the last 35 years. So i have learned alot the hard Way. I dont want anyone to Think i am a know it all. But there is no reason You all need to learn it that Way. Im happy to share. I am a professionel bodyman and do accident repairs as a liwing. The old us cars are only done on the side. But some of the modern tecniqes can also be used on the old cars. Also some oldschool can be used on moderne cars, although there is not alot of metal left in them. Its more plastic now.
PS im kicking myself as i gave away a set of wheels like that 15 years ago. Back then they was not cool. Now im thinking Real hard about making a clone of a SE in Dark red candy with the correct stribes and spoilers. But without the wheels its not complete. And as you now its hard to find some correct ones. 15 years ago they where everywhere. Now all gone
Page 2 of 21
» Rear coil spring help
» ~~Introduce Yourself~~
» Whats it worth?
