Goodies left from my build.
Goodies left from my build. Empty Goodies left from my build.
Post by Joe73 on Mon Oct 14, 2019 1:31 pm
Have a bunch of items left over from my engine build.  Everything is new and unused unless otherwise noted.  If anyone is interested.  Giving you guys first shot.  I'll put it up on FB later tonight.  Message if your interested in anything.  Thanks.
SBC Polished aluminum timing chain cover with bolts, seal and gasket  $25 shipped
Fel Pro 1405 exhaust gasket  $15 shipped
MSD 8213 side mount coil bracket (Have two)  New one $5, used one $3
Centerforce Roller Pilot bearing 43001  $15 shipped
HEI wire retainer
ARP Header Bolts,  Stainless,  HEX head  $15 shipped
ARP Oil Pan Bolts, Stainless, HEX head $20 shipped
ARP Timing Cover Bolts, Stainless, HEX head  $12 shipped
ARP Valve Cover Bolts, Stainless, HEX head $10 shipped
7/16” Long Poly Locks for stud girdle (16) $15
Scorpion 7/16” Poly Locks (came with my roller rockers) full set of 16  $10
3/8” rocker studs brand new removed from my new Promaxx heads (16) hex  $15
Spectre Grade 8 flywheel Bolts 4698  $3
Spectre Billet 42555 SBC Oil dipstick and tube with O ring fits 65-79 $10
(6)  Blue Plug Wire Heat Sleeves
Starter stud and shim kit SBC  $9
Side Terminal Battery Disconnect $5
Taylor 45469 Coil Wire $5
ARP Ultra Torque Fastener Assembly Lube $3
Summit Performance Assembly Lube $5
Battery Cable w/clamps   ½” wire, 14 feet long  $50 shipped
Goodies left from my build. Engine10
Goodies left from my build. Engine11
Goodies left from my build. Engine12
Goodies left from my build. Engine13
Goodies left from my build. Engine14
Goodies left from my build. Engine15
Street Cred : 78
Goodies left from my build. Empty Re: Goodies left from my build.
Post by Joe73 on Mon Oct 14, 2019 1:32 pm
Street Cred : 78
Post by g3chevy on Mon Oct 14, 2019 2:13 pm
Joe, do you think the timing cover will work with an Edelbrock double roller timing set? I've read that some timing chain sets won't work with these aluminum timing covers. If it does work, I'm interested. Thanks!
g3chevy
g3chevy
Street Cred : 22
Post by Joe73 on Mon Oct 14, 2019 2:49 pm
My mistake. The timing cover is sold as well. Thanks
Street Cred : 78
Post by Joe73 on Mon Oct 14, 2019 2:53 pm
Ok, updated list.  Sold items are removed.
HEI wire retainer
Street Cred : 78
Post by Joe73 on Mon Oct 14, 2019 9:25 pm
Updated list.
HEI wire retainer
Street Cred : 78
