[FS] 8.5" 10-bolt posi differential
I have a 8.5" corporate 10-bolt 3.08:1 posi differential out of a 1988 Caprice 9C1 (cop car). It has 126,000 KM (78,300 miles). It is in very good shape and has the EATON clutch style posi in it, not the crappy non-rebuildable Auburn that GM used from 1989 and onwards. Axles are 28 spline. Has 11" drum (wagon) brake backing plates on it currently, but does not come with drums. Wheel bolt pattern is 5x5. This is a direct bolt in from what I am told for '73-77 A-bodies.
$300.
Located in Vancouver, BC, Canada.
$300.
tayto- G3GM Newbie
Re: [FS] 8.5" 10-bolt posi differential
A bodies don't have the 5 X 5 wheel lug spacing....
no they don't you are right BUT they can be re drilled for 4.75 Small chevy and yes they are a direct bolt in rear with mod needed to only the Park Brake bracket, And that's a steal at that price if in good shapepila wrote:A bodies don't have the 5 X 5 wheel lug spacing....
Pulling the axles & getting them re-drilled should be easy enough if there's a place locally to do it.
You could also get unilug wheels.
wally has 5x5 on all 4 corners of that 74 chevelle he got.
i think "thatfnthing" has 5x5 on his monte too.
1973montec- Donating Member
Does anyone know, are the axles different besides the bolt pattern (5x5)?
Is it possible to transfer the older axles over (73-77- A body - 4.75) to this rear, both should be 28 spline?
I'm looking for a posi myself, this ones a great deal but way too far away from the Northeast.
BK-75- G3GM Member
1973montec wrote:wally has 5x5 on all 4 corners of that 74 chevelle he got.
I have a stock G3 8.5" posi rear, so it has the 5 x 4.75" spacing, but my front spindles are from a 93 Caprice, which uses a 5 x 5" rotor. Â The wheels are all 5 x 5.5", so I run adapters at all four corners, but they're obviously different front to back. Â Since the wheels have 6" backspacing, the adapters also help locate them properly in the wells. Â Been running it this way (and lightin' them up) for ~5 years now with no problems.
Yes axles can be redrilled or new axles ordered with correct bolt pattern. If you are running the B-body spindle you can convert the whole car to 5x5, which is the way to go in my opinion because you can then run factory rear disc brakes (bolt ons). You can also get a 88-93 F-body "1LE" rotor (GM #18027886) for the B-body spindle that is 12" in diameter and 4.75x5 bolt pattern.
tayto- G3GM Newbie
» Posi or "high traction differential" decal in trunk
» Are the new '120mm' 5 bolt wheels equal to 4.75" 5 bolt older style wheels?
» 75 differential
» 75 differential
