trying to get the rpms down a little bit
+4
novaderrik
badbiscayne66
8 posters
trying to get the rpms down a little bit Empty trying to get the rpms down a little bit
Post by 74442guy Thu Sep 10, 2009 3:43 pm
im running a 464 big block olds 455 punched 40 over 10.1 comp big comp cam headers flowmasters and 410 eaton posi was wondering what would be the best way to drop the rpms with out killing the take off im running a turbo 350 but have a built turbo 400 being built for her any help would be grate
74442guy
74442guy
trying to get the rpms down a little bit Empty Re: trying to get the rpms down a little bit
Post by JB2wheeler Thu Sep 10, 2009 4:40 pm
I do not understand your question. Just guessing what you mean, you could put a 4.42 posi in it and the super torque of the 455 will pull it off the line alright. JB
Street Cred : 28
Post by 74442guy Thu Sep 10, 2009 4:50 pm
do you mean a 3.42 cause 4.42 is bigger than my 4.10 and at 65 my rpms are around 3,500 and up the faster you go but is sick off the line
74442guy
74442guy
Post by badbiscayne66 Thu Sep 10, 2009 6:09 pm
try a taller rear tire!! or a od trans .......350 and 400 turbo both have 1 to 1 high gear so no change there!!!!
badbiscayne66
badbiscayne66
Post by The Dude Thu Sep 10, 2009 8:52 pm
In all honesty, if your 455 has too much gear anyways. You are probably fighting for traction right now & redlining before the traps right? 4.10s are for small blocks and non-torque making Chebbies, lol. I'm willing to bet you could drop down to 3.42s or 3.73s & get the results you're looking for while improving your 60ft times. Just depends on what your car is mainly used for.
Street Cred : 48
Post by BlackChevelleSS Thu Sep 10, 2009 9:07 pm
taller tires and 3.73s
trying to get the rpms down a little bit SIG2
Street Cred : 20
Post by The Dude Thu Sep 10, 2009 11:00 pm
OK. I've been playing around with DD2003 so you can get an idea. Realize that Desktop Dyno is usually about .5 second faster than real life, but this should give you something to think about. Also, I threw in the 3.08s not because I recommend them, but because it shows that torque motors like Olds don't need as much gearing. Remember you got a full 1/4" more stroke than a 454 Chevy!
All tests were with aggressive driving, "typical" track conditions, optimized wheel spin (which I'm pretty sure you won't get with 4.10s), 2,500 stall (just guessing), & 26" tires. I also went with the TH400 since you said you were swapping one in.
Gears 4.10 3.73 3.42 3.08
E/T 12.326 12.129 12.160 12.249
MPH 99.4 109.4 113.67 112.7
0-60 3.762 3.833 3.914 3.998
RPM 5500 5500 5274 4708
Note the 5500rpm on both the 3.73 & 4.10 gears. That was DD's predicted redline for the motor. The 4.10s were bouncing off 5500 RPMs at 1,000 ft. I can get more accuracy if you want to shoot me more numbers or tell me what I need to change. One thing to really look at is the 3.42s won't give you as much wheel spin as the 4.10s or even the 3.73s which means in reality you're gonna get better 0-60 times. Also, the 3.42s give you the highest mph of all 4 gear ratios; indicating these would be your best choice with this set-up.
Street Cred : 48
Post by BlackChevelleSS Thu Sep 10, 2009 11:40 pm
26" tire is too small set it up with a 28" tire which is a 275/60/15
Street Cred : 20
Post by The Dude Fri Sep 11, 2009 12:08 am
I made a whoops on my original chart, so I fixed it to 0-60 instead of 60 ft Embarassed Anyways, here you go Dan. This is what 3.73s & 28" tires would do:
Gears3.73
E/T12.151
MPH113.8
0-603.904
RPM5352
Looks nearly identical to the 26" tires with 3.42s.
Street Cred : 48
Post by novaderrik Fri Sep 11, 2009 12:36 am
go with 3.08 gears unless you are seeking out the absolute last .010 second in the 1/4 mile.
with all that torque, it will still be fast, but it will be not only more pleasant but also easier to drive. and you will have a scary fast top end charge if you should find a place to open it up.
novaderrik
Post by 74maroonmonte Fri Sep 11, 2009 4:04 pm
Here are a few other calculators to mess around with tire size and rear gears:
http://www.ringpinion.com/Calc_RPM.aspx
74maroonmonte
74maroonmonte
Post by JB2wheeler Fri Sep 11, 2009 8:41 pm
74442guy wrote:do you mean a 3.42 cause 4.42 is bigger than my 4.10 and at 65 my rpms are around 3,500 and up the faster you go but is sick off the line
Yes! I did mean a 3.42. Nothing unusual about my typing mistakes. JB
Street Cred : 28
Post by Limey SE Sat Sep 12, 2009 12:00 am
Nope thats why we love ya JB
Post by 74442guy Thu Sep 17, 2009 1:15 pm
thanks for all the help love those charts if i could get low 12s like the chart i would be happy as heck lol that would be awsome for a street car
74442guy
74442guy
