Antifreeze leak
Antifreeze leak
Not my El Camino, but I backed out my completely stock 1986 Monte Carlo SS with the HO 305 and had an antifreeze drip. I have not investigated this very far yet but it looks like antifreeze is collecting in the flywheel cover and dripping out a small hole in the bottom. I’m sure I am going to hate the responses but does anyone have an idea as to where it would be leaking from. I don’t see any oil in the antifreeze or antifreeze in the oil.
77camino- G3GM Enthusiast
Re: Antifreeze leak
The way you wrote it almost seems like a trick question, May I ask what the hole is doing there in the first place? Is it in fact a crack in the housing?
76Chevelle2Tone- G3GM Member
Re: Antifreeze leak
Not a trick question. The antifreeze is leaking from somewhere on the back of the block and collecting in the belly of the flywheel cover. There is a small factory hole in the bottom of the cover that the antifreeze will drip out of, definitely not a crack there.
Re: Antifreeze leak
Is there a gasket in there? Not having a mix of coolant and oil narrows things down but I doubt there is only one failure mode for this. Do those Montes have plugs in the back?
Re: Antifreeze leak
77camino wrote:Not a trick question. The antifreeze is leaking from somewhere on the back of the block and collecting in the belly of the flywheel cover. There is a small factory hole in the bottom of the cover that the antifreeze will drip out of, definitely not a crack there.
I know not the answer you want but inwould lay money on a freeze plug failing since not being driven alot
Re: Antifreeze leak
I agree with Limey, frost plugs could be the issue. Have you checked the heater hose connection at the rear of the intake? it probably wouldn't leak from where you are describing, but you never know. You could add some dye to the coolant to help trace the leak.
76 Malibu- G3GM Member
Re: Antifreeze leak
There is 2 core plugs in the back of the block.
Re: Antifreeze leak
Thanks for the thoughts. Are the freeze plugs replaceable while the engine is in the car?
Re: Antifreeze leak
I think it depends on the particular model what is in the way. 1986 Montes are not G3 obviously. Better make sure it's them leaking first.
Re: Antifreeze leak
If it's the rear freeze plugs, you'd have to remove the transmission, and the flex plate to get at them. It's not the easiest job, so hopefully it's not them leaking. It's a long shot, but if the rear coolant fitting on the intake is leaking, it could be making it's way into the bellhousing and dripping out. That would be a much easier fix.
Wed Oct 23, 2024 10:05 am by Redscampi
» Things are looking up
Wed Oct 23, 2024 7:56 am by Redscampi
» Central Texas Noob
Wed Oct 23, 2024 7:33 am by Redscampi
Tue Oct 22, 2024 11:18 pm by Limey SE
» vinyl top removal
Tue Oct 22, 2024 8:28 pm by 76Chevelle2Tone
Mon Oct 21, 2024 12:58 pm by 76Chevelle2Tone
» Life & Back On The Radio
» fuel gauge malfunction?
» 1973 Grand Am Parts Needed
» 73 laguna trim
