Woohoo!
Woohoo!
I finally found my buildsheet!
I had thought it was on top of the gas tank and in tatters much like my 76 was or gone since the tank looks to be a replacement tank
I was poking the satelite radio antenna wire through the back seat, and out pops this folded sheet of paper, sure enough its the build sheet in nearly pristiene condition. Going to make a good copy of it, and stick the copy back in the car, and frame the original sheet.
Confirms what I already knew about the car except the street addess of the dealership.
texan01- G3GM Member
Re: Woohoo!
That IS awesome! I pulled my two out from the inside back of the fenders and am preserving them in a clear plastic protective folder. I've been told there might be a third Build Sheet hiding up on top of the gas tank...as was often the case with Montes being built at the Leeds plant.
Re: Woohoo!
I'm holding out to hopefully find mine in the drivers door as that is the only part of the interior not torn out......did they really put them inside the rear wheel wells?
Re: Woohoo!
I've only found them in the doors, or stuck under the front seat in the springs.
Sat May 18, 2024 1:56 pm by REVINKEVIN / Mr. 600+HP
Sat May 18, 2024 12:20 pm by g3chevy / Mr Pontiac
Fri May 17, 2024 4:38 pm by Mcarlo77
» Dash Solutions
Fri May 17, 2024 3:22 pm by 76 Malibu
» Window louvers
