Gas Smell
Gas Smell
The last couple of times I have put gas in Monte and parked in the garage, the whole garage smells like gas for the next couple of days. Is this normal, I just noticed it the last couple of times I have put gas in it. Could it be venting from somewhere around the fuel tank? Thanks
KC77Monte- G3GM Member
Re: Gas Smell
I am not sure if it does or not. Maybe a fuel line going bad?
Re: Gas Smell
That happened to me.
In my case it was a fuel leak in the steel line close to the catalytic converter. The leak could not be found until the crack in the line open and pour gas on the floor.
Be careful as gas vapor explodes. Turning the lights on in your garage can be enough to start a ball of fire if the room is not vented.
I suggest you to take care of it asap. One way to do is to go for a drive, then check every connection and use your nose to pinpoint the area.
76malibu- Donating Member
Re: Gas Smell
I had that happen. For me, the carb leaked into the manifold after the car was shut off, so every time you went to start it again later, you had to crank until it refilled the bowl. In the meantime, the garage would reek of gas for the next 24-48 hours.
Re: Gas Smell
Mine only does it after I have filled it up. I got to looking last night and the odor is strong around where the filler tube meets the tank, plus it is damp around that area. I pumped about 5 gallons out and this morning I hardly noticed the smell. I'll check again tonight to see if it still smells. Looks like it might be new tank time.
Re: Gas Smell
You need to check the hoses that connect the fuel & vent lines to the tank unit.....the sender & fuel pick-up...above the tank.
I sure wouldn't park in a garage, until the leak has been fixed !!
Today at 5:02 pm by Matchstx
Today at 4:56 pm by Matchstx
Today at 2:48 pm by Limey SE
» Window louvers
Today at 12:47 pm by JCervantes10
» 1973 Chevelle SS 1 Family
