Opera window removal
I have some rust and I’ll probab need it to be welded right below both opera windows. Has anyone removed them how am hard is it? Thank you
JF74chevelle- G3GM Member
Re: Opera window removal
No big deal removing the opera windows. Just remove the retaining clips on the inside (behind the sail panels) and use a flat blade to break the butyl seal around the perimeter.
Mcarlo77 wrote:No big deal removing the opera windows. Just remove the retaining clips on the inside (behind the sail panels) and use a flat blade to break the butyl seal around the perimeter.
Okay thank you very much for the advice
The fastest way I've learned to remove these is with a windshield removal tool like the one in the link below. Just cut the wire about double the size of the opera window and start it in the top hard corner and "saw" your way down. Takes about 30 seconds and its out.
https://www.ebay.com/itm/Car-Windshield-Removal-Tool-Windscreen-Window-Glass-Cutting-Wire-Handles-Kit/142800256758?epid=508513298&hash=item213f8efef6:g:aq0AAOSwC19a~3tn
- Street Cred : 34
