Finally made it out to the track
coreys73chevelle
It's been over a year since I went drag racing, but I made it out Friday night. The car ran 11.90's @ 117mph, but I couldn't hook up to save my life. Looks like I need bigger slicks, the 9.5x28" MT slicks just weren't cutting it.
My best 11.95 @116.86mph
https://www.youtube.com/watch?v=ibjmhDqW7Mc
This one is of my buddy and I racing. His 69 Camaro took 2nd in the World of Wheels back in 1999. It's a sweet ride.
https://www.youtube.com/watch?v=TFSQjcBDHEM
74Malibu383- Donating Member
Re: Finally made it out to the track
on my other car buddy i always ran the 10.5" wide and ALWAYS HOOKED
29 x 10.5 x 15
29 x 10.5 x 15
Yeah, but did you have over 500HP & TQ at the rear wheels?
that car had right around 425 horsies
At the motor? I think I'm pushing 650+ at the motor.
No at the wheels it had 428 to be precise (DYNO PROVEN), and sad to say let all the paperwork go with car to new owner
what procharger do you have? i am planning on getting a D1SC with an Intercooler set at 9psi
That's the exact set up I'm running. Keep in mind you'll have to use a blow-through carb and completely redo your fuel system. (From what I can see in your photos.)
what do you mean?? i will get a holley car and a different manifold a the same time also pretty soon ill have aluminum heads. the fuel system i have now is adjustable PSI from 7psi to 14psi
so you should be running low 11s according to the 117mph trap speed. Sounds like your putting down some power. what you have in the motor? My bro has a afr aluminum head 383 with holley stealth ram and a P1SC. hes running a cog set up and is only getting 5psi boost. The engine has seen 13psi before the crank broke at the balancer. Im trying to get him to go to the track.
I also have a friend with a procharged 03 mustang. Its stock motor with bolts ons. headers, underdrive pulleys, and alot of suspension mods in the rear. hes running 8psi and its been dyno'd tuned. It put out 400RWHP and ran 12.77 at 117mph. on drag radials, didnt hook at all. He never took it back out with the drag radials because of fear of breaking something.
BlackChevelleSS- Management
If I could hook up, I'm sure I would be in the low 11's instead of the high's. The motor isn't anything special, but has GM Fast Burn aluminum heads. I'm running 8.5psi on 91 octane, and have all the little goodies that keep everything safe. I'm putting down 525RWHP and 515RWTQ, so I definitely have enough power.
The ProCharger was an after-thought though and the motor doesn't have forged pistons. I plan on pulling it out after January and putting forged internals in it. ProCharger told me I would have a conservative 725HP at the block once I do a pulley swap.
yea my bros car has hyperutectic pistons but it has forged i beams and steel crank and it was running 13psi on race fuel.
Sounds like a lot of boost for a non-intercooled car without forged internals. Good luck to you guys, hope nothing breaks.
Yea, we hope so as well but hes trying to get an intercooler and get more tuning done. The crank kept breaking before at the balancer, kind weird and it was an eagle steel crank.
I would like to see how yours does with some traction and some more boost.
Mine should be in the 11s all motor next year if I get a tire on it that will hook. My best pass was 12.39@111mph on street tires. I got a lil blue bottle that im gonna put in it too 10s here we come.
Don't you worry. After the forged pistons go in, increasing the boost won't be all I'm doing. The car is already plumbed, wired, and itching for the blue bottle. I put it on the car before the ProCharger, but don't dare use them together YET.
I've got a MSD Timing Retard controller/remote bottle opener installed and just begging for the pistons. I don't know what it will do, but I'm excited.
Nice times, cant wait to see what it'll do with some traction. BTW post some pics of your car, Its one of my favorite G3's
alowerlevel- G3GM Member
He had some posted here, but for some reason my work computer isn't showing them.
https://www.g3gm.com/nominee-s-for-ride-of-the-week-f25/1974-malibu-t573.htm
Probably a glitch on my end.
I don't see them there anymore either. However, I did throw two up on that Calendar thread.
https://www.g3gm.com/general-discussion-f1/gonna-make-a-g-3-calendar-submit-your-best-pics-t1197-15.htm
» 1973 Chevelle SS 1 Family
