My once stolen Chevelle back on the road!
+4
MaliCrusier / Mitch
8 posters
Page 3 of 4
Page 3 of 4 • 1, 2, 3, 4
Re: My once stolen Chevelle back on the road!
73ss wrote:That's good, If you'r new head gaskets are .035~.040, consider thinner. you need all the compression help you can get. Hi performance cams bleed off compression, That's why they all list a minimum compression ratio, typically 9:1 or higher.
Replacement pistons are typically in the hole more than it was from the factory. The manufacturer assumes the heads and block have been milled.
Very true, all reasons why i'm building a higher compression stroker later. Or just buy a short blick with a warranty.
MaliCrusier / Mitch- G3GM Member
That's what it looks like is a Bearing came with it
Limey SE wrote:That's what it looks like is a Bearing came with it
So my wife wins the Big Brain award here becaus she asked if i had pulled my fuel pump pushrod yet... Cam came right out after that lol
Crow is good sometimes though LOL I though you already took that out LOL
"Marry yourself a smart woman."
Truer words were never spoken, my friend.
Looks like the seat belt inter switch if Belts arent fastened for lack of better term
Is there a way to ditch it?
MaliCrusier / Mitch wrote:Is there a way to ditch it?
Yes there is. I will have to verify what wires, but you simply jump across the whole system near the fuse box/ bulkhead connector. It is all in the starting circuit (purple wires) if memory serves me correctly.
If you can start the car without the seat belts locked, someone has probably already bypassed it. The button on that box is the override (one time) if the car doesn't crank with the seat belt engaged.
bigredlaguna wrote:If you can start the car without the seat belts locked, someone has probably already bypassed it. The button on that box is the override (one time) if the car doesn't crank with the seat belt engaged.
It fires up just fine without being buckled, but the wires still seem unmolested.
The jumper bypass probably won't be very obvious. I found a thread on another site that does a good explanation of what needs to be done to bypass the system.
https://www.stevesnovasite.com/threads/bypassing-neutral-safety-switch.306810/
That site also has some really good diagrams that cross over effectively since all GM cars used the same color coding.
Sweet thank you!
Looks to me like the engine already in your car is a 400. I see steam holes in the pic of the .030 piston.
bigredlaguna wrote:Looks to me like the engine already in your car is a 400. I see steam holes in the pic of the .030 piston.
That's my donor engine, my original engine was busted by my younger brother and my lq9 was taken when my car was stolen and stripped so....donor car to the rescue.
Oh, I must be misunderstanding the timeline or something. So the donor car's engine was already in your car, and now you are doing the top end on it, correct?
Man, I love Arby’s.
- Street Cred : 19
» Finally, back on the road!
» Back I am, sorta + 2011 Road Trip notes/pics
» 1974 Chevelle 454 – Last454 - Back on the Street
Page 3 of 4
