cown decode?
cown decode?
hello i have a 76 laguna white/red stripe looks to be pretty orig Issue is 1st the car has a reissued vin from ohio for unknown reason so it covers the das vin and their is another tah on the rear cross frame rail=
hers my question seeing a 19 and 19 on the cowl tag under pain and i think that is Black upper and lower
hears it is
ST 76N 1AE37 D105239 BODY
TR 19N A65 19L 19U PTN
01A 11A
can someone help and tell me what this means ?
thanks
hears it is
01A 11A
thanks
rocketman17j- G3GM Newbie
Re: cown decode?
At first glance, this is what I see.
1ae37 2 door sport coupe Laguna
19L 19U All black car
A65 bench seat with arm rest
19N Black vinyl deluxe interior.
If the car is a small block, take a look behind the alternator. Clean the area and you will notice the engine block sticks out a bit further than the cylinder head. There should be a number stamped there with some letters. That will give you the original last six digits of the VIN and the engine and trans combo it originally came with. As long as someone didnt "restamp" the block and/or changed the engine or trans.
Reissued VINs are for cars that had their original, factory installed, vin plate removed for some reason like theft, retagged (stolen) or possibly rotted away and someone went the legal way to get a vin for it.
Re: cown decode?
You are correct...#19 indicates Black upper and lower. Also, the #19N A65 indicates a Black bench seat interior.
ST 76N verifies a 1976
1AE37 verifies it's a Laguna S-3
D 105239 verifies it was built in Doraville, Ga (D). Numbers are just a production sequence number)
01A would indicate a build date of 1st week(A) of January(01)
Not sure what the 11A indicates (possibly white body side stripes)
Re: cown decode?
01A, that should have rang a bell for me. Same build date week as my 73.
Re: cown decode?
awsome guys thank you someone did a good jpb changing the color i couldnt tell
Re: cown decode?
thanks good paint job no way i knew it was black
i would inv a pic but have no idea how to
Re: cown decode?
Is it possible that body tag was removed from another Laguna? Would think you'd see evidence hidden somewhere that it was originally a black car.
Joe73 likes this post
Yesterday at 10:21 pm by lagunaman
