1973 Chevelle SS Station Wagon
+8
Mitchell Murphy
Iggy
mldinneny
S3TPI
bucket
12 posters
Page 1 of 3
Page 1 of 3 • 1, 2, 3
This thread will have no real direction, it is mostly just to help me keep track of what has been done, what needs done, and my findings along the way. If folks are interested in seeing it and reading about it, that's even better, lol.
I came across this car a couple years ago. It was the second SS wagon I had seen in person, with the first being spotted about 15 years before that. I was finally able to strike a deal and brought it home a few days ago.
Looking at paperwork in the glove box, the car was purchased new at Bobb Chevrolet in Columbus Ohio, by a couple in the Westerville area. They had the car until around '84. It was then possibly purchased by someone in the Grandview area, they had the car until '92. It was then purchased by a fellow in London Ohio who drove the car until around '97. Then it sat in a barn until it wound up at his buddy's used car lot a couple years ago, which is when and where I found the car. Now I own the car and it is back in the London OH area.
bucket- G3GM Member
Re: 1973 Chevelle SS Station Wagon
The car seems to be wearing it's original paint still. I only question the LR door and the front section of quarter panel, it looks as if the black paint may have been blended in at some point early in the car's life. There's also a scuffed/scratched area that has a light purple sealer exposed. There's also a halo in the paint in the same area.
That is the reason I believe that area had been repaired post-'73. But then I noticed that the left A-pillar has the black paint peeling off and the same color sealer is visible.
What color sealer was used in '73? Is it possible that there was a blemish at the factory and the paint was repaired at the factory? That halo/discoloration came from somewhere. Either way, I plan to fully document the placement of the lower body striping so it can be replicated later on down the road.
bucket- G3GM Member
I have removed the 2GV carb for an overhaul, that will be the first step in the fuel system rehab.
The emissions label on the radiator support states Federal and California compliant, where applicable. I'm not exactly sure what the "where applicable" part means.
Also, it turns out that I know the car owner from 1992-2019, so that's pretty cool. I haven't talked to him in a few years, hopefully he's still alive and kicking.
bucket- G3GM Member
I will also be removing the smog pump and related parts, as well as the charcoal canister. I will replace the fuel cap with a vented unit. All stock parts that get removed and not reinstalled will be boxed up for potential use in the future.
bucket- G3GM Member
Mounted up some custom painted IROC-Z 16" wheels because they look better than the S10 14" rims and bad tires that were on it. I'm not sure what I think of them yet, pretty sure I still want to run a set of 15x8 rallies.
I also realized that I actually know the owner from '92-'19-ish. I'm bad with names so it took a lot of hints before it finally rang a bell in my head.
bucket- G3GM Member
Very cool SS! Had a chance to trade for one with a member here a few years back. I kick myself for not doing the deal! Keep the posts coming!
- Street Cred : 34
I got a hood for my 76 elcamino in Blue Springs MO. He has one of these in his garage ! Not sure if it the same SS talked about in this thread ? Thanks.
mldinneny- G3GM Newbie
Most of the stuff seems to be from the late 80's to the early 90's. I know that 99.7fm has been The Blitz since at least '92. I don't recall exactly when those ugly California Raisins characters were trendy.
I also got the original polycast wheels with the car. All caps are accounted for, but a couple of the rings are a little banged up.
bucket- G3GM Member
Automotive archeology always turns up interesting stuff!
- Street Cred : 34
looks like the 1980's a calling, they want their trash back!
Iggy- G3GM Member
The bumper looks good, did you have to make some brackets to relocate it?
S3TPI- G3GM Member
S3TPI wrote:The bumper looks good, did you have to make some brackets to relocate it?
Theres actually a member here that makes relocation brackets to move the bumpers in
I flipped the factory "side" brackets from side to side, turned them around and re-mounted them to the center brackets, after drilling holes to get the placement right. Right now, the bumper is actually only bolted to the bottom of the brackets. I have square tube spacers bolted to the top of the brackets that push up against the backside of the bumper to keep it supported for now.
It's functional for now, but when I find a decent bumper without all the extra trim holes, I will fab up a couple upper brackets that utilize the factory bolt holes. If all else fails, I'll shave all the holes in the stock bumper and have it re-chromed.
bucket- G3GM Member
Limey SE wrote:ÂS3TPI wrote:The bumper looks good, did you have to make some brackets to relocate it?
Hmm. I was not aware of that. Oh well, I guess I at least got a little satisfaction from rearranging factory parts to make it work, lol.
bucket- G3GM Member
Cool car. Here in Copenhagen in the 80s we had alot of elcos and wagons. I always had a soft spot for them. But sadly they are all gone now and rare. I guess all died from the salt on the vinter roads. However in the 80s you could have on running and driving for 1500 dollars. Nowadays if you find one its more like 20 000. I sold a fully restored 73 elcamino with 350 and auto for 15 000 some years ago. I would kill to have that wagon.
Hs1973- G3GM Enthusiast
They are a rare sight around here these days too. This one is certainly a little rough, but at least it still exists! Lol. I talked to the guy that owned the car from '92-'19 and he was happy to know that I intend to put the car back on the road. He said when he last drove the car in the late 90's, it was running and driving well, even the AC was operational.
I don't have much left to do, just put the carb back on and put a battery in it. But that will have to wait until I get back home from working out of town. But the wheels are on and the car is finally off the trailer. The trailer made a nice work surface so I didn't have to lay on the ground.
bucket- G3GM Member
Limey SE and S3TPI like this post
Yes, really neat piece of Super Sport History, Always will wonder why did Chevrolet decide to do this? I had a 454 car in the Chamois Color and neutral interior. Everywhere, and I mean everywhere I drove the car, it was a magnet, and pulled all kinds of people up to the car asking questions about...talk about a conversation piece? Wow...Only thing I added was the factory gauge cluster with the Tach, to me all 454 cars, this should have been standard OEM on the cars. Thank you for buying this car, take your time, Do it right, and when you go to sell it, it may do right by You, Mitch
Mitchell Murphy- G3GM Member
Page 1 of 3
Today at 12:36 am by Limey SE
