im going to look at a 75 malibu tomorrow
maliburacinfreak
HDHugger
so im going to look at a 75 malibu tomorrow hopefully getting the door glass, and a few other little parts, wish me luck lol anything i should look for on this?
cromags76 BANNED- G3GM Member
- Street Cred : -6
Re: im going to look at a 75 malibu tomorrow
cromags76 wrote:so im going to look at a 75 malibu tomorrow hopefully getting the door glass, and a few other little parts, wish me luck lol anything i should look for on this?
good luck
yeah send me some swivel bucket seat belts, eschelouns and the belt guides! In black!!!
HDHugger- G3GM Member
If you get the door glass & all of the window hardware is still good, snatch it up. You can thank me later when one goes pop. Check out all of the trim pieces too. Even though most parts are available for our cars now, good trim is still hard to find. LOL that didn't come out right.
lmfao and i already have a whole spare set for both doors they came off the old rusty doors i had before i put my malibu ones on my elky and i was thinking about looking for some rare trim and emblems and stuff like that
apparently its dark blue interior and the front end is like gone with no motor or trans
im looking at the door glass, the header panel on the back right side, and the whole plastic clip on the back that holds everything together(which i hope will work with the 77 malibu), some dash pieces its round guages, and i hope this is a 75 malibu classic with the door bumpers and all the emblems on it, i would be in heaven!!
- Street Cred : -6
so i went and looked at the car today
got the drivers glass, wiper motor, chrome side mirror, the whole ac box with the dryer and evaporator and blower, and the hood lock bracket, and the door panels all for 70 bucks
tell me if thats a good deal i think it is
he has a whole rear end (i dont think its a posi) that he will sell to me for 100 bucks thats with the springs and all the trailing arms and stuff i might do that idk yet tho
he was telling me something about the cutlass rear end that you can pull the axles out easily or something???
- Street Cred : -6
Sure, just get a strong chain and a stronger tree... wrap the cahin around the axle... floor it. Let us know how that works out.
no i mean take the axles out of the rear end, he said they just slide out, and on the other cars like mine you have to take out something before they slide out
- Street Cred : -6
The Olds 10 inch rear end is what came in my 74 Elky from the factory. They ran out of Chevy rears so they just popped an Olds rear under it because it was available and they did not want to shut down the assemblyline. The Olds/Buick/Pontiac rear is the same as the Chevy except it does not have the C clips holding the axle in, it is bolted in and if you break an axle you don't have to worry about the wheel and axle flying out like a Chevy would. JB
JB2wheeler wrote:The Olds 10 inch rear end is what came in my 74 Elky from the factory. They ran out of Chevy rears so they just popped an Olds rear under it because it was available and they did not want to shut down the assemblyline. The Olds/Buick/Pontiac rear is the same as the Chevy except it does not have the C clips holding the axle in, it is bolted in and if you break an axle you don't have to worry about the wheel and axle flying out like a Chevy would. JB
yep yep thats it thats what he was saying
man i am going to have to get one of those
and my bad but im only 17 and i dont know anything about posi
can someone explain that?
- Street Cred : -6
without the Posi, if you floor the car in snow or gravel the power will go to the wheel that is spinning the most and not giving you traction. With Posi, you have a series of clutches in the rear that forces the wheel with the most traction to take the load of power and get you going with less spinning. JB
JB2wheeler wrote:without the Posi, if you floor the car in snow or gravel the power will go to the wheel that is spinning the most and not giving you traction. With Posi, you have a series of clutches in the rear that forces the wheel with the most traction to take the load of power and get you going with less spinning. JB
alright i understand what you are saying but cant you put a mini spool in it or something? to get both wheels to spin
- Street Cred : -6
you can but spools suck on the street and mini spools break. theyre only recommended for dirt racing. posi is the way to go for street usecromags76 wrote:JB2wheeler wrote:without the Posi, if you floor the car in snow or gravel the power will go to the wheel that is spinning the most and not giving you traction. With Posi, you have a series of clutches in the rear that forces the wheel with the most traction to take the load of power and get you going with less spinning. JB
maliburacinfreak- Donating Member
Check out this entry on Wikipedia. Should get you all 'learned' up on rear ends.
http://en.wikipedia.org/wiki/Limited_slip_differential
And congrats on the smoking deal for all those parts. Good find.
74Malibu383- Donating Member
BlackChevelleSS or BlueChevelleSS would be the guys to ask on the mini spool thing. The 73 that I got from them had a mini spool at one time & they drove around on it. I believe it's now underneath Blue's 454 powered 73 SS that gets drove on the street. Basically they permanently lock both axles together causing them to spin at the same speeds no matter what. I would assume chirping tires when turning, tires wearing out quicker, & a PITA on the snow.
To check for positraction, lift the car & spin one wheel.
Both tires spin same direction > posi.
Opposite direction > non-posi.
I would personally ask to pull the diff cover & count the teeth on both the ring & pinion, inspect everything, get visual confirmation of posi or not. If you aren't allowed to do that, then there may be something the owner is hiding.
74Malibu383 wrote:Check out this entry on Wikipedia. Should get you all 'learned' up on rear ends.
haha ok and thx, i am thinking about getting all the interior he would give me a good deal, all the plastic is good and the seats are useable just need to be recovered, and its all off of a 75 malibu classic, so it has the same opera windows as my 77 malibu
- Street Cred : -6
Rago wrote:BlackChevelleSS or BlueChevelleSS would be the guys to ask on the mini spool thing. The 73 that I got from them had a mini spool at one time & they drove around on it. I believe it's now underneath Blue's 454 powered 73 SS that gets drove on the street. Basically they permanently lock both axles together causing them to spin at the same speeds no matter what. I would assume chirping tires when turning, tires wearing out quicker, & a PITA on the snow.
cant you just install a regular spool the heavy duty ones? instead of the 20 dollar mini spool, and i know my elky doesnt have posi, and he is going to sell me a rear end that isnt posi for 100 with the springs and all the trailing arms and junk
is that a good deal? i am just wanting to clean it up and paint it then put it right in (that is after i change the gear oil) with no problems
- Street Cred : -6
I'm not sure why you want to swap one complete rear end without posi, for another without posi. Is something wrong with your current set up? Seems like a lot of work for no real gain.
74Malibu383 wrote:I'm not sure why you want to swap one complete rear end without posi, for another without posi. Is something wrong with your current set up? Seems like a lot of work for no real gain.
no no no the picture of my car is when i got it
i ended up selling that rear end out of it cuz the car was origionally for parts to restore my elky (hence why both of my cars have the same bumper on it lol ) and i sold a bunch of other parts out of it, then i came up with the crazy idea to restore it lol so now i need another rear end but its technically like im just gettomg a rear end back for the money back cuz i sold the rear for 50 and the springs and trailing arms for 50 lol
- Street Cred : -6
There is nothing wrong with an open rear end on roads that are not slick. They are a minor disadvantage in snow. If you use a good snow tire you should be all right. Of course if you will be drag racing you should have a posi. Forget the spool on the street, it wears out tires very quickly. What I used to do before they had posi was to weld the spider gears in the rear and that was the same as a spool. I drove that on the street without any problems, but kept tearing it out at the strip. JB
JB2wheeler wrote:There is nothing wrong with an open rear end on roads that are not slick. They are a minor disadvantage in snow. If you use a good snow tire you should be all right. Of course if you will be drag racing you should have a posi. Forget the spool on the street, it wears out tires very quickly. What I used to do before they had posi was to weld the spider gears in the rear and that was the same as a spool. I drove that on the street without any problems, but kept tearing it out at the strip. JB
yeah well i live in florida so i dont have to worry about snow, and no i am not drag racing, just daily driving, but i would at least like to do a good burnout here and there you know?
- Street Cred : -6
» Dropping the tank tomorrow
» Chevelle 540 going on dyno tomorrow. Take a guess for power
» '77 Chevelle Malibu Classic - Disco Malibu
