remote mirror panel bezel
ok...another question for you all. On my 76 malibu, I have a remote mirror control on the driver side. I took off my upper door panel and the backing of this control has 2 prongs that stick through the door panel. It looks as if these two prongs should have a backing nut on it to hold it in place. Does anyone have any idea if this is how the control is secured to the door panel, and if so, where I can find these backing nuts. My controller is loose obviously. Thanks in advance.
Jeff
Jeff
A_Tame76- G3GM Member
Re: remote mirror panel bezel
A hardware store should have them. I think they are called speednuts.
BlackChevelleSS- Management
BlackChevelleSS wrote:A hardware store should have them. I think they are called speednuts.
Thanks Black!
a step further on the remote mirror
I am trying to remove mine from the 74 Laguna parts car. The upper panel is off, and the mirror is off. where does the cable come apart so i can get this away from the door? Right now they are hanging one inside, the other outside.
autorecycler- G3GM Member
from what I remember, theres a small flat retainer clip on the back of the little controller part for the remote. Remove that retainer and you should be able to seperate the cable from the remote and then from the door panel.
any tricks to removing that retainer?
I believe that if you flex it slightly, it should slide right out.
lol.... this car was parked under a tree at the edge of the Okeefenokee Swamp for 10 years. Nothing slides right out. however with a little work we got it out, thanks.
» driver's side remote mirror bezel locking tab FOUND
» Remote mirror cable routing.
» passenger side manual remote mirror
