Gauge Cluster Acrylic (glass)
I know most of you have done this so I need advice. I just took the dash bezel off the 77 to clean and paint(turned out awesome by the way) and was putting it back together and I'm not happy with the plastic-acrylic whatever you call it. Have any of you used anything to clean it up real good? No scratches just looks like water spots or something.
Re: Gauge Cluster Acrylic (glass)
Laguna Budman wrote:I know most of you have done this so I need advice. I just took the dash bezel off the 77 to clean and paint(turned out awesome by the way) and was putting it back together and I'm not happy with the plastic-acrylic whatever you call it. Have any of you used anything to clean it up real good? No scratches just looks like water spots or something.
Only thing I would / could suggest is the headlight cleaner ?? or hardware store for new acryllic they have it in the same size use your old one as a template
I've got the same problem, I tried maguires plastic polish, it helped, but still isn't great.
How do you separate the glass from the bezel without tearing it up? Then how do you get it back on? My plastic is held to the bezel with what looks like plastic welds, I've been too chicken so far to cut the welds off, cuz I don't know how to get it back on without buying a plastic welder.
I use a hot knife, save the plastic that comes off, and use the hot knife to melt it all together again. You could also drill the posts so you can use a small screw to hold the pieces together.
I thought about that, I'm just afraid I'll mess it up and I DO NOT want to try and replace it.$$$$$$$
Are you gonna try to clean your "glass" up or just replace it with something?
I just cleaned it as good as I could with both the headlight cleaner and plastic polish. Still has some imperfection in it, but it looks a lot better than before and it isn't something to make me stop using it.
The hot knife method isn't that difficult. I didn't even touch the clear part. I had it apart in less time than it took to type this- literally.
The hot knife I have has a variety of tips, so i used other tips to use the plastic nubs I cut off to build up and reshape the post that was cut, and then to mash the plastic back down upon reassembly.
Most of the time all I had to do was just move the plastic over so the clear piece could move. I only had to cut the post underneath the clear piece if the post was really mashed like a rivet, most of the time whoever assembled these just kind of laid the post over enough to hold the clear piece.
I didn't look for material to replace it with, though it would be easy to do.
I'll try your method and see what happens, If I screw it up I'll send you a bill.
i used a lighter nd a knife to get mine off
i heated up the weld and cut it off with the knife and the plastic came off perfect
ive done it twice with the same perfect result and i even got it on some how too and it looks great!
its honestly easier than it sounds just have to have a little common sense
Hey just found a solution. A buddy of mine owns a glass shop and had some 1/16 Lexan layin around. Very bendable and I drilled holes and put it in with small screws and it looks good. Did ya know you can cut that stuff with tin snips(crazy)
nice thats a good idea i should do that it would look a lot cleaner
