98 Monte Carlo starting problem.
Page 1 of 2 1, 2  Next
Post by 74MonteCarlo on Sat Jun 12, 2010 8:58 pm
Some older members may remember last summer when I was having starting problems on my 98 MC. I went all Winter with ZERO issues. They're back! Only difference: hot, humid weather. WTF. Only when it's hot outside is when it happens. It ended in the Fall when it cooled down, and our first day of 80+ degree weather(about 3 weeks ago), it wouldn't start. Happened last night and again tonight. Me and my dad are totally baffled.
Street Cred: 16
View user profile
Re: 98 Monte Carlo starting problem.
Post by coreys73chevelle on Sat Jun 12, 2010 9:00 pm
any check lights on? check engine light on?
coreys73chevelle
Street Cred: 8
View user profile
Post by 74MonteCarlo on Sat Jun 12, 2010 9:05 pm
Service Engine is on, but even when it was off it happened. I think it's for the A/C. I think it may have a tiny little leak and the free-on is low. When we charged it the first time, it went off. Went back on again when I started using it. I've done every process of elimination possible. Only conclusion: HOT WEATHER.
List of things I have replaced thinking it was the problem:
Starter
Battery
Ignition key
I think there's something else I'm forgetting...
I was going to get a new ignition switch, until I found out it was $125. Not gonna spend that if I'm not 100% sure that's the problem.
Street Cred: 16
View user profile
Post by coreys73chevelle on Sat Jun 12, 2010 9:11 pm
coil packs?
coreys73chevelle
Street Cred: 8
View user profile
Post by 74MonteCarlo on Sat Jun 12, 2010 9:12 pm
Wouldn't that be all time time?
What baffles me is it's only when it's hot!
Street Cred: 16
View user profile
Post by coreys73chevelle on Sat Jun 12, 2010 9:15 pm
does it crank or is it like a dead battery?
coreys73chevelle
Street Cred: 8
View user profile
Post by coreys73chevelle on Sat Jun 12, 2010 9:20 pm
could be ignition control module, fuel pump relay OR it could just be bad vapor lock witch you get a new gas cap or leave it loose and let it air out then try to start it
coreys73chevelle
Street Cred: 8
View user profile
Post by coreys73chevelle on Sat Jun 12, 2010 9:22 pm
ignition switch could be it also. http://www.srtforums.com/forums/f25/hot-day-car-wont-start-449614/ read the last post on the 1st pag says i was it
coreys73chevelle
Street Cred: 8
View user profile
Post by 74MonteCarlo on Sat Jun 12, 2010 9:25 pm
Like a dead battery. I forgot to mention, that after 2-5 minutes letting it sit there, it will then start, NO problem.
Street Cred: 16
View user profile
Post by JB2wheeler on Sat Jun 12, 2010 9:32 pm
Does this happen the first time you crank it in the morning or does it happen after you have been driving it and then shut it off and come back in a short time and try to crank it. JB
Street Cred: 21
View user profile
Post by IndyG3 on Sat Jun 12, 2010 11:08 pm
Is it humid when it's hot? You could possibly have issues with connectors...
IndyG3
Street Cred: 11
View user profile
Post by HDHugger on Sun Jun 13, 2010 12:24 am
Did you check your blinker fluid levels? Razz
HDHugger
Street Cred: 6
View user profile
Post by 74laguna on Sun Jun 13, 2010 2:01 am
if the key has a chip in it you need to check the lock cyl. wires for the theft system
74laguna
Street Cred: 0
View user profile
Post by 74MonteCarlo on Sun Jun 13, 2010 5:54 am
JB2wheeler wrote:Does this happen the first time you crank it in the morning or does it happen after you have been driving it and then shut it off and come back in a short time and try to crank it. JB
It happens at random. It doesn't matter when I last started it.
Street Cred: 16
View user profile
Post by 74MonteCarlo on Sun Jun 13, 2010 5:55 am
IndyG3 wrote:Is it humid when it's hot? You could possibly have issues with connectors...
Doesn't matter. Just anything 80 or more degrees.
Street Cred: 16
View user profile
